I would steer clear of 46's. But either of the above would be a more suitable option.
Quantums seem to have produced an excellent alternative for the VX & after I had a back to back test on track with quantums & 46's. The quantums were noticeably better in certain circumstances & i'm converted. That's what I'm replacing my 46's with this month.
Very interesting. May I ask what your spec is on the car such as ride height, geo, tyres, spring rates?
In what way did the quantum feel better? Like in low speed or high speed, turn in, exit.
Edited by Tonie Pettersson, 08 June 2015 - 10:27 AM.
So I did the mistake to move the car with the air bag disconnected --> nice red lamp showing. If I don´t want to take the car to Opel/Vauxhall dealer, is this the magic thing I´m looking for?
Hi Toni. Have you painted your lamps inside? Looks good.
Also saw you to ok away the diffuser for the MOT, why? With ny installation I wont be able to use my std diffuser. Either I will got to the MOT without one or with the new one Im going to make.
Br, Per
Tonie - I have an OPCOM if you need anything done. We're not THAT far away :-)
Good to know, thanks for the offer . Going to Sviestad on Monday?
You're welcome anytime :-)
Unfortunately no track day for me, still working on the gear cables. Actually think I finished the cable work yesterday but there is still some work to do (centre console, seat, hand brake, undertrays, cleaning the cabin, cleaning up all the gear box oil that got away last time etc). I also put on the stock wheels for this years MOT.
Last time I looked (about 10 minutes ago) the bridge resistance should be 2 ohms +-0.2.
Br, Per
All these decisions...
I´ve been doing a geo on the car, so now it has this spec
Front
Camber left 1°39'
Camber right 1°47'
Castor left 4°14'
Castor right 4°14'
Toe left -0°02' (toe out)
Toe right -0°02' (toe out)
Rear
Camber left 2°37'
Camber right 2°25'
Toe left 0°13' (toe in)
Toe right 0°13' (toe in)
Also installed the diffuser (again, took it off for the MOT) and a new steering wheel with the snap off. The Corsa B boss I bought didn´t fit on the spline.
Luckily I had some saved parts stored from the old Nova project, found a boss that fit on the spline.
Soldered in cables for the horn and a resistor for the airbag, unfortunately I bought 2.2ohm instead of 2.7 so the light is still on. So just ordered the correct resistor, should turn up in a day or two.
Hi Toni, I red this on the Opel forum, written by you.
"Justerade dämparna lite hårdare runtom och gav mig ut på första passet (ganska sent, vid halv tolv efter flaggvaktspass och så brukar trafiken på banan lugna ner sig lite).
Kändes bra ett par varv men sen började det understyra en del ihop med att bakvagnen var lömsk.
Hade ett jätteställ efter bron och det berodde inte på gasavsläpp utan det bara släppte.
Som tur var redde jag ut det men lite lätt skitnödig blev man .
Blev då in och justera lite lufttryck och släppa lite på dämparna, resultatet blev en helt annan bil."
Can you explane this more detailed. How hard did you have the shocks from the begnning and how did you change them?
What tire pressure did you hve and what did you change too?
Do you have stiffer ARB? If so how do you feel the difference?
I´m a little slow updating here I see. Been on two track days now and the car is still alive .
First one was on a track I know fairly well so I was really looking forward to see how my new parts would feel.
Unfortunately it was like 300° that day so the grip wasn´t really there. Still managed to do ~120 miles so I was really pleased.
Next track day was on a new track for me and with new pads, switched from Mintex 1155 to Performance Friction 08.
It was like night and day if you compare the pads (not so strange though if you look at what the pfc cost....), now the car really bites and it doesn´t matter if I´m on lap 3 or 14. There is a rather heavy brake point on the track, from 110mhp to 40 but it was really consistent.
Now I have some time off before next track day. The car feels really nice except for in turn in, having problems to "turn the car over", under steer. I have no under steer mid/exit corner.
Going to do a new geo next week and add some more camber front (2.3) and also going to try with some more toe out and hope it will solve my problem.
Any other ideas?
Br, Per
I started the day with 7 front and 4 rear (from hard) and aimed for 1.9 front and 2.0 rear. Struggled to keep the tyre pressure since it was really hot so had problems to keep the grip at the rear.
Loosened the damper to 12 front and 8 rear and tried to keep the pressure on 2.0 and the car felt much more nice.
I run Nankang NS-2R TW180 (in 235/40-17) rear and not RSR as you do so your car might react differently though.
A stiffer arb yes, EP´s 1" in stiffest setting.
Edited by Tonie Pettersson, 17 July 2015 - 10:52 PM.
Check this primauto.net/LotusServiceManualEliseS2/elise/Extras/Steering_Setups.pdf Useful to adjust your car settings to stop under steer at a corner entry.
