At least its the cold end thats closest to the CV boot. Great work BTW
2.2 Turbo
#21
Posted 20 February 2015 - 12:53 PM
#22
Posted 20 February 2015 - 03:56 PM
Ok, some coolant questions:
[color=rgb(20,20,20);font-family:'PT Sans', sans-serif;background-color:rgb(252,252,255);]Here's the schedule from MarkV on the VX coolant flow:[/color][color=rgb(20,20,20);font-family:'PT Sans', sans-serif;background-color:rgb(252,252,255);] [/color]
I'm going to get the coolant feed from the waterpump (from drain bolt).
[color=rgb(20,20,20);font-family:'PT Sans', sans-serif;background-color:rgb(252,252,255);]A) If I am correct, the z20net has a return in the "main outlet"? Correct?[/color]
[color=rgb(20,20,20);font-family:'PT Sans', sans-serif;background-color:rgb(252,252,255);] The US Cobalt guys say to put the return into the "secondary outlet", straight back to the reservoir. I think this would not be such a great idea since you are warming up the cold water that is suppose to cool the engine (warm out and warm in....). Correct?[/color]
[color=rgb(20,20,20);font-family:'PT Sans', sans-serif;background-color:rgb(252,252,255);]C) Tapping into the thermostat means you recirculate the hot water into a cold circuit and putting hot water into the engine. Not that good. Correct?[/color]
[color=rgb(20,20,20);font-family:'PT Sans', sans-serif;background-color:rgb(252,252,255);]I would go with option A. Any comments on this one? Thanx![/color]
[color=rgb(20,20,20);font-family:'PT Sans', sans-serif;background-color:rgb(252,252,255);]For about the close turbo/driveshaft issue: The DBilas kit is even closer (with the hotside of the turbo in the driveshaftboot direction!) and holds up so far. Except for some melted gearcables here and there ....[/color]
#23
Posted 22 February 2015 - 09:35 PM
Ok, so bought this :
Put my waterreturn into the "main outlet".
Modified the OEM heatshield and looks and fits fine so far:
Drilled my banjo bolt to 1.5mm as a oilrestrictor for the non ballbearing turbo:
Got myself a 2.5" Imhof backbox so now I can sort out the rest of the exhaust.
#24
Posted 10 March 2015 - 09:50 PM
#25
Posted 12 March 2015 - 01:27 PM
looking intersting
#26
Posted 13 March 2015 - 10:45 PM
Got a saab intake today from Exmantaa.... thanx mate
TB-hole is 60mm
TB and ECU fit perfect 1-on-1
Manifold shuts the OEM pcv hole (from cilinderhead 2 -3) perfect shut.
Shut the manifold pcv to prevent unmetered air coming in in vacuum situation
Perfect fit with 120A alternator
#27
Posted 14 March 2015 - 10:11 AM
#28
Posted 31 March 2015 - 08:34 PM
#29
Posted 31 March 2015 - 11:08 PM
How much boost will you use ?
#30
Posted 01 April 2015 - 07:35 AM
Max. 0.8 bar / 12 psi.
#31
Posted 01 April 2015 - 07:52 AM
I'm really hoping this works well ::
#32
Posted 01 April 2015 - 07:58 AM
Just a thought after looking back through your pics.....
You may want to slot the exhaust flange in between the cylinders or elongate the holes for the exhaust studs. Stainless expands quite a lot and log manifolds like this can end up snapping studs off if they don't have a bit of wiggle room.
#33
Posted 01 April 2015 - 09:19 AM
Yes I know, thank you. Most of them are m10 size with a M8 stud but a few were very tight so I opened them later on to M10 size hole. Should be sufficient I guess?
#34
Posted 01 April 2015 - 11:42 AM
Should be fine.
Can't wait for the result
#35
Posted 24 April 2015 - 09:56 PM
[color=rgb(20,20,20);font-family:'PT Sans', Arial, sans-serif;background-color:rgb(252,252,255);]Short updat so far:[/color]
[color=rgb(20,20,20);font-family:'PT Sans', Arial, sans-serif;background-color:rgb(252,252,255);]TMAP 2.5 bar placed. Used the OEM MAP hole but the gap is alrger then the rubbe r0-ring. So a little ghetto helper to keep the sensor down.[/color][color=rgb(20,20,20);font-family:'PT Sans', Arial, sans-serif;background-color:rgb(252,252,255);] [/color]
[color=rgb(20,20,20);font-family:'PT Sans', Arial, sans-serif;background-color:rgb(252,252,255);]Blocked the crackhole to prevent dirty oil vapors getting into the manifold.[/color]
Working in the intercooler
... and the exhaust. Need some small stuff for it so will be done next week. A wideband and OBD-tuner and I think we're ready to roll.
#36
Posted 24 April 2015 - 11:21 PM
#37
Posted 24 April 2015 - 11:28 PM
looking good!
#38
Posted 26 April 2015 - 08:32 AM
For the map sensor I think you can take the rubber bung off, wrap some tale round the peg and then put the rubber bung back on. Still ghetto but looks OEM
#39
Posted 12 May 2015 - 08:41 PM
Little update.
Got myself OBD-tuner.
Put poly inserts in while we're there..
Weak moment of thinking I guess. Dipstick behind the IC piping. Still works but no perfect access...
Did some weight meassuring: Minus 7,5 kg from oem exhaust (manifold till endtip) and that is inc. 5 kg heavy turbo! Pleased.
Have to finish exhaust and wideband and hope to start her up in two weeks.
#40
Posted 12 May 2015 - 09:23 PM
Nice progress on an interesting project
