Edited by gingerjon, 16 May 2015 - 11:28 AM.
Still No Life.....even After Relay Swap
#81
Posted 16 May 2015 - 11:28 AM
#82
Posted 16 May 2015 - 11:35 AM
This may sound daft but have you changed the fuse even if it looks ok?
#83
Posted 16 May 2015 - 11:41 AM
#84
Posted 16 May 2015 - 11:51 AM
do you have 12v at pin 86 brown wire - brown relay coil ?
do you have 0v at pin 85 - brown relay coil ?
Sometimes the pins are reversed, that does not matter, what is important is whether you have both the 12v and 0v feeds.
As the relay outputs work okay (when power is manually added to the relay coil and the fact that pin 86 12v feed comes directly from the relay 12v main supply - pin 30) that you are not getting the 0v from the ecu (green/pink wire)
The green/pink wire goes through pin 12 on X2 the blue plug behind the coolant tank (one half of the loom of doom), you should confirm it is coming from the ecu by tapping into the loom before it reaches the X2 plug from the ecu. This will prove if it's the x2 blue plug or the ecu.
can you confirm you have 12v at pin 86 and 0v for three seconds when the ignition is switched on (brown relay)
plus the relays are in the correct location, brown in the five wire holder and grey in the four wire holder
Edited by vocky, 16 May 2015 - 12:03 PM.
#85
Posted 16 May 2015 - 12:27 PM
#86
Posted 16 May 2015 - 04:38 PM
so you have no 12v at the Brown relay then, you need to follow the Brown wire(s) from the 5 pin relay base back towards the battery, they join together and then should go to the plug and socket I posted on the previous page of this thread
#87
Posted 17 May 2015 - 06:07 PM
Thanks Vocky, we were running through things for about 3 hours yesterday, i have just stuck an update in my project thread but alas i have given in.
Going to try and get it to BOT in a couple of weeks to sort it out and try and get it back on the road.
Thanks so much for everyones help on this thread though, i really appreciate it.
J
#88
Posted 17 May 2015 - 06:28 PM
#89
Posted 17 May 2015 - 06:46 PM
Thanks Lee, Its a pain!! Tried 2 of each relay and cleaned and re-crimped all plugs.
Its starts with the extra power, but dies as soon as removed!! just hoping BOT can solve it!
