Still No Life.....even After Relay Swap
88 replies to this topic
#41 CHILL Gone DUTCH
Posted 06 April 2015 - 11:23 AM
Are your seats out See if your getting voltage at pump
#42 FLD
Posted 06 April 2015 - 11:26 AM
Do you have power at the pump?  Just wondering if the pump is fooked.  If the relays melted and the pump just ran and ran it could have knackered it.
#43 gingerjon
gingerjon
  • 587 posts
Posted 06 April 2015 - 11:46 AM
Yep, we put 12v through the relay harness directly last week and the pump primes and pressurises the system. I've tried different relays too. A friend is coming over again with a multi metre in a bit. Bored now.
#44 CHILL Gone DUTCH
Posted 06 April 2015 - 11:49 AM
Are the pins bent in relay holder or wires come uncrimped
#45 G-Bob
G-Bob
    Embarrassing VX's in an MX5
  • 8,256 posts
Posted 06 April 2015 - 11:51 AM
it does sound like the ecu has been fried by the melted relays  :(​
That's exactly what happened to mine.   The relays melted and took the ECU with it.
If you can't connect to the ecu by the port either it's a clear sign.
Borrow GL's ecu to see if it's that and if it goes, then buy it off of him.
Edited by G-Bob, 06 April 2015 - 11:52 AM.
#46 gingerjon
gingerjon
  • 587 posts
Posted 06 April 2015 - 11:55 AM
Pins seem fine, connections are tight. I have swapped the ECU today G-Bob, but the scanguage also just still says "connecting"
#47 CHILL Gone DUTCH
Posted 06 April 2015 - 11:56 AM
Could be immobiliser issue Is your stack still reading 999
#48 G-Bob
G-Bob
  • 8,256 posts
Posted 06 April 2015 - 11:57 AM
Have you swapped the chip in the keys and made sure there isn't another one nearby?
#49 CHILL Gone DUTCH
Posted 06 April 2015 - 11:59 AM
When your mate gets to you Get him to check the outgoing switch feed to the pump for voltage
#50 gingerjon
gingerjon
  • 587 posts
Posted 06 April 2015 - 12:00 PM
Other tansponder chip is on the other side of the house and new one in key in ignition. Stack still flashing 999 yep.
#51 CHILL Gone DUTCH
Posted 06 April 2015 - 12:02 PM
Try reset your dash
#52 gingerjon
gingerjon
  • 587 posts
Posted 06 April 2015 - 12:05 PM
By pushing the trip button with the door open? Tried that last week, can't ever seem to get it to do it. Thanks everyone for the Bank Hol assistance, really appriciate it.
#53 Bargi
Bargi
  • 4,483 posts
Posted 06 April 2015 - 01:02 PM
Sounds like wires to ECU. 999 is Stack failing to see ECU and message from Scanguage seems to confirm that. If you completely unplug the ecu is there any difference?
#54 Bargi
Bargi
  • 4,483 posts
Posted 06 April 2015 - 01:04 PM
The other check is of course putting your ECU on another car to fully eliminate your ECU as the problem.
#55 gingerjon
gingerjon
  • 587 posts
Posted 06 April 2015 - 01:15 PM
With the ECU disconnected, the stack still reads 999 and scanguage won't connect. Exactly if the ECU is plugged in. So the stack is not talking to the ECU, but would this affect the fuel pump priming? Does the circuit go through the stack at start up?
#56 Bargi
Bargi
  • 4,483 posts
Posted 06 April 2015 - 02:04 PM
Yes, ecu controls the fuel pump. My guess would be some of the wires in the loom have melted as well when the relays went. Time for a multimeter and some soul destroying checking of wires :)
#57 gingerjon
gingerjon
  • 587 posts
Posted 06 April 2015 - 06:33 PM
Sooo, after 6 hours of soul destroying multi meter-ing.....its inconclusive. We tested a variety of things - headlines for the people who actually know about this: Green Pink wire into ECU relay has 0.006v when ignition on, and around 0.2v when stater button pressed Tested green/pink wire back to ECU and it has continuity Tested white/violet wire for fuel pump relay to ECU and it has continuity We tried by passing the fuel cut off switch We did however manage to get the heap running : Ignition Off Brown relay bypassed Direct 12v feed to : 12V to Pin 86 0v to Pin 85 relay had to be in place Ignition turned Fuel pump primed Stater pressed Car fired and ran (My new tullet is quite antisocial it turns out!!!!) temp back to normal briefly Scanguage connected fine When feed to relay removed from 12v supply.....car turns off. I would add that we also tested the relays to ensure they both 'fired' when fed 12v. What do we think? Apart from 'what a ballache'......
#58 vocky
Posted 06 April 2015 - 06:48 PM
check the power for the brown relay at the loom of doom plugs, could be them causing the issue
#59 gingerjon
gingerjon
  • 587 posts
Posted 06 April 2015 - 07:37 PM
Thanks Vocky, I did check and clean the connector today to but didnt check the power directly. Will add it to the list for next week.
#60 gingerjon
gingerjon
  • 587 posts
Posted 12 April 2015 - 05:52 PM
Okeydokey, another quick update...
New brown relay - Makes no difference.....
Until power directed applied, stack still reads 999 and ScanGuage will not connect
I have stripped the loom as far as i can in the front - no damage
I have stripped the loom back to the connectors in the back - No Damage
I have cleaned the Connectors and ensured no dust /dirt - Still nothing....
I wanted to send it to BOT this week to get it back on the road but don't really want to dump it on there in its state AND not starting!
Any other last wisdom out there? think i should get an AutoElectrician out?
GJ
