Misfires At 2000Rpm
223 replies to this topic
#201 vocky
Posted 27 July 2016 - 11:15 AM
Vocky - I'll give that a go but might be a bit tricky underneath!
use a longer straw on the aerosol can thumbsup
#202 The Batman
Posted 27 July 2016 - 11:54 AM
Edit: you also dont "need" them alignment bungs, they just make it easier.
I suggest always fitting these. As otherwise the intake can sit in a incorrect location
#203 chris_uk
Posted 27 July 2016 - 12:18 PM
Its highly unlikely to cause an issue.. As long as all the other bolts are in place it cant sit out of line as they line it up also. Ive seen ali pipe being used which is the perfect size to slide in with m6 id and they work just as well.
#204 The Batman
Posted 27 July 2016 - 12:34 PM
All the bolts are designed for m8 not m6 so there is approx 4mm movement therefore it can sit unaligned especially when using a brand new lower mount
#205 The Batman
Posted 27 July 2016 - 12:39 PM
#206 chris_uk
Posted 27 July 2016 - 12:43 PM
Maybe thats why lukes arse dyno only registers 313bhp.. :lol:
#207 The Batman
Posted 27 July 2016 - 12:45 PM
:lol:
#208 DaveyC
DaveyC
  • 259 posts
Posted 27 July 2016 - 01:26 PM
Good stuff, well these should be arriving tomorrow.
#209 CHILL Gone DUTCH
Posted 27 July 2016 - 01:28 PM
Don't put your self down it was 316
And a Obd reading
#210 chris_uk
Posted 27 July 2016 - 02:43 PM
Wow i weighed a lot that day!
#211 CHILL Gone DUTCH
Posted 27 July 2016 - 04:22 PM
Have you lost weight recently ? 😆😆
#212 The Batman
Posted 27 July 2016 - 09:51 PM
Yes, more hair has fell out
#213 CHILL Gone DUTCH
Posted 27 July 2016 - 09:53 PM
Mine fell out years ago
#214 The Batman
Posted 27 July 2016 - 10:01 PM
Must be a northern thing..
#215 siztenboots
Posted 28 July 2016 - 02:48 PM
Who drew that graph, Michael J Fox , or the animator for Roobarb cartoon?
#216 chris_uk
Posted 28 July 2016 - 02:58 PM
I dunno why its like that. Once i start mapping it again i will see if its the same.
#217 TFD
TFD
  • 607 posts
Posted 28 July 2016 - 04:26 PM
Looks like your timing is shot. Either due knock or due bad ignition map.
#218 CHILL Gone DUTCH
Posted 28 July 2016 - 04:55 PM
To be fair to Chris at this point when this power run had been done he hadent done any map alteration to the car So as far as a base start goes it's not that bad If you look carefully you can see a fair amount of knock retard which may or may not be from engine
Edited by CHILL Gone DUTCH, 28 July 2016 - 04:57 PM.
#219 DaveyC
DaveyC
  • 259 posts
Posted 29 July 2016 - 02:56 PM
I have now fitted the top hat sleeve things and it hasn't made a difference. Worth a try though!
I'll give the brake cleaner a go tomorrow.
#220 vocky
Posted 29 July 2016 - 03:20 PM
don't spray the stuff everywhere and spray only for a few seconds, it is flammable stuff :ninja: , so allow it to evaporate before spraying the next bit :P
