That's good news and hope it helps the othersThis afternoon I changed the primary lambda for another one OEM replacement, and the car turn to go fine. No misfires and strange things. Probably this will be ypur problem, but how Peter says in the tutorial, ecu is too much sensible to lambda readings, so it has to be an VX original replacemet. Hope this info will help.
Misfires At 2000Rpm
#161
Posted 28 January 2016 - 07:29 PM
#162
I have replaced mine recently and it made no improvement.
I have also run the car without it in the exhaust and the exact same misfire was present.
#163
Posted 28 January 2016 - 07:56 PM
Was it oemI have replaced mine recently and it made no improvement. I have also run the car without it in the exhaust and the exact same misfire was present.
#164
Posted 28 January 2016 - 07:57 PM
#165
Posted 28 January 2016 - 07:58 PM
Are you sure you plugged the lambdas into the right plugs also as there is a spare plug on some cars which is easily confused And be 100% there oem Primary and secondaryYeah. Or at least it was sold as OEM and cost as much as OEM.
Edited by CHILL Gone DUTCH, 28 January 2016 - 07:59 PM.
#166
Posted 28 January 2016 - 08:00 PM
#167
Posted 28 January 2016 - 08:02 PM
#168
Posted 28 January 2016 - 08:05 PM
#169
Posted 28 January 2016 - 08:41 PM
So you had the exact same misfires with the old engine; so different head and cams... Really strange.I'm on comp cams blower cams. These were timed by Vocky. Had the same problem with standard cams in my old engine before it exploded, the timing chain was most recently replaced by Vocky on that one too.
#170
Posted 28 January 2016 - 08:43 PM
#171
Posted 28 January 2016 - 08:57 PM
#172
Posted 29 January 2016 - 06:24 AM
Unfortunately I have changed the plug on mine because I needed the standard one elsewhere so it won't be a simple swap :/
I'll see if I can find the part number of the sensor I fitted. 99.99999999% sure it is legit as Peter stressed the importance of an OEM lambda sensor.
#173
Posted 29 January 2016 - 09:32 AM
#174
Posted 29 January 2016 - 09:40 AM
Yeah I needed the plug to use for the fuel pump and couldn't source one from anywhere so I used the lambda sensor one and replaced the lambda one with a generic waterproof plug.
Not really sure how to check the wiring - all is fine with a multimeter, I triple checked all the wires before wiring it up and I get traces you would expect to see in OBD tuner which correspond with the output of my wideband sensor.
Various set-ups over the past 18 months:
Old Courtney mapped ECU on old engine - had the problem
Bought a replacement ECU and sent it to Peter for OBD tuner for use on the new engine - still had the problem
Swapped the lambda sensor - still had the problem
Replaced the lambda sensor plug - still had the problem
#175
Posted 06 February 2016 - 10:47 PM
When comparing dave's transient table to a few others, the throttle % really catches my eye.
It's so far off everybody elses i have seen.
Wonder what that does.
#176
Posted 06 February 2016 - 10:56 PM
#177
Posted 06 February 2016 - 11:15 PM
Mine is exactly the same as DaveyC's.
Bummer.
Can you post your transient table?
#178
Posted 06 February 2016 - 11:59 PM
#179
Posted 07 February 2016 - 12:10 AM
That does exactly what is descibed; throttle flap speed (as % of max speed)...
Two different settings; a slow one for stationary and (normally) a quicker flap-speed map while driving. Davey's drive response will be a bit sluggish with those settings.
#180
Posted 08 February 2016 - 01:09 PM
