1. Leevx2.2
2. The batman
What's the code name?
Wet tight flaps?!
Your mum wants a sequential box?
Posted 09 June 2015 - 04:18 PM
1. Leevx2.2
2. The batman
Wet tight flaps?!
Posted 09 June 2015 - 07:32 PM
I need to find time to ring in the day, thats why I rang on the weekend.
Sorry if I'm holding people up..
Posted 09 June 2015 - 07:39 PM
Hey guys, is it too late to join on the groupbuy? Or is it max 10? I didn't want to add my name to the list before I was certain that I wanted this ARB. Is the alloy sleeves required (I have an early 2.2).
Posted 09 June 2015 - 08:33 PM
No you are welcome to join just call Elise parts and place an order it isn't limited to 10
Posted 09 June 2015 - 09:11 PM
Same here. Will try at lunch tomorrowI need to find time to ring in the day, thats why I rang on the weekend. Sorry if I'm holding people up..
Posted 09 June 2015 - 11:26 PM
Great! Is alloy sleeves required if ARB is stock? I have a 2001 model 2.2
Posted 09 June 2015 - 11:28 PM
Posted 10 June 2015 - 10:20 AM
Posted 10 June 2015 - 12:00 PM
My order has been placed. I think I make 10 officially ordered with them
:: Looks like we're there. I wonder if it'll arrive for the weekend
Posted 10 June 2015 - 12:22 PM
Posted 10 June 2015 - 01:00 PM
I'm indeferent; my heap is broken
Posted 10 June 2015 - 01:31 PM
Posted 10 June 2015 - 01:38 PM
Had a flat battery (probably an alarm fault) and its left it with the immobiliser not recognising the key. P1614 IIRC. I'm hoping disconnecting the battery will solve it or I'll have to get it towed to the stealer. They want 100 quid just to look at it before applying any fix. Thieving gits.
Posted 10 June 2015 - 02:36 PM
Did they mention when they will be despatched Can you confirm ten has been orderedMy order has been placed. I think I make 10 officially ordered with them
Posted 10 June 2015 - 02:47 PM
I'll probably be in the same boat soon, battery disconnected for 12 months.
Maybe this is the best opportunity to move to the OBD tuner?
Posted 10 June 2015 - 03:08 PM
Only if OBD tuner allows access to the immobiliser.
Posted 10 June 2015 - 03:15 PM
Yeah, I've read that. I'm hoping some general poking around and disconnecting the battery will help.
ETA: its just the trouble at t' mill thats stopped me trying it yet.
Edited by FLD, 10 June 2015 - 03:16 PM.
Posted 10 June 2015 - 03:36 PM
Apparently the 1inch bar is stronger on the minimum setting than the 7/8Why is this ARB better than the £140 Elise-shop arb, which is 2.25x stiffer than the std one? Is the 1" from Eliseparts much better quality, or is 7/8inch diameter not stiff enough? Both are adjustable.
Apparently the 1inch bar is stronger on the minimum setting than the 7/8 on full hard .Why is this ARB better than the £140 Elise-shop arb, which is 2.25x stiffer than the std one? Is the 1" from Eliseparts much better quality, or is 7/8inch diameter not stiff enough? Both are adjustable.
Does that make it 3x stronger?
LOL!
if you use X1 as the std ARB, then:
7/8" one goes from ~2.3 - 4 X
1" one goes from ~3.5 - 5.9 X
1 1/8" one goes from ~5 - 8 X
realistically, std one does nothing, it;s not till you get to at least 3-4X that you start to feel a significant change.
Having run Geary's VX on the 1", I would suggest that's the minimum I would suggest, for an all out track car I would be looking at the 1 1/8".
Also, stronger is the wrong word, stiffer is what your looking at, which is why it makes almost zero odds what steel you use for an ARB, as although T45 is stronger, it's not stiffer than basic CDS.
Hope that helps...
PS, here's a vid of how they were tested...
Edited by Scuffers, 10 June 2015 - 03:39 PM.
