Normally Aspirated ... Of Course
60 replies to this topic
#41 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 18 February 2016 - 11:26 AM
Really nice power output.
How much extra bhp did you get from the mapping?
Br, Per
#42 vocky
Posted 18 February 2016 - 05:41 PM
I really have no idea, this was the first time the 2.5 engine has been mapped.
#43 vocky
Posted 18 February 2016 - 05:50 PM
What sort of power/torque would this conversion net with the webcon gear?
The Webcon throttle bodies kit is just a starter pack, you need to consider what bhp you want and then source the parts required. To get past 200 requires the balancer delete and 11:1 CR, some cams, a ported head and a decent 4-1 manifold and 2.5" system.
Stage 1 cams are usually around 200-210 bhp, stage 2 cams 210-230 bhp, stage 3 cams 220 - 240bhp. After that CatCams do some nice cams, I run their 287 versions.
#44 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 18 February 2016 - 06:37 PM
Great result. Must be one of the nicest vx power trains anywhere! It must be very well built to be able to rev a long stroke engine well above 7k rpm. What's the mean piston speed at max rpm?
#45 TheHood
TheHood
  • 1,036 posts
Posted 18 February 2016 - 08:13 PM
MPS will be 24.5m/s @7500RPM. VERY nice work Vocky.
Edited by TheHood, 18 February 2016 - 08:14 PM.
#46 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 18 February 2016 - 08:20 PM
 You dont know how much bhp you gained between first and last pull? How much extra bhp did you get from the mapping?
#47 vocky
Posted 18 February 2016 - 08:25 PM
It made 255 bhp at 7100 on the first run, now it makes the same at 6250 rpm
#48 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 18 February 2016 - 08:55 PM
  The Webcon throttle bodies kit is just a starter pack, you need to consider what bhp you want and then source the parts required. To get past 200 requires the balancer delete and 11:1 CR, some cams, a ported head and a decent 4-1 manifold and 2.5" system.   Stage 1 cams are usually around 200-210 bhp, stage 2 cams 210-230 bhp, stage 3 cams 220 - 240bhp. After that CatCams do some nice cams, I run their 287 versions.
Like these cams? http://www.vx220.org...e-schrick-cams/ ;)
#49 Ali87
Ali87
  • 1,287 posts
Posted 18 February 2016 - 11:12 PM
What a beast, you should bring it on the Hoon!
#50 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 19 February 2016 - 07:56 AM
Any videos of it in action or have you taken it back apart already to continue fettling?
#51 Rosssco
Rosssco
  • 4,183 posts
Posted 19 February 2016 - 12:31 PM
Vocky's 2.5 engine with slightly larger bore will have a bore / stroke ratio will have pretty much the same as a standard 2.2 engine. Plus he has a lightened, balanced crank and various under drive ancillaries like the water pump and alternator..
My basic 2.4 rev's as easily / keenly as a 2.2 for example, again because it has a very similar bore / stroke ratio.
#52 Exmantaa
Posted 19 February 2016 - 12:47 PM
It's more the rod-length vs.crank-stroke ratio that determines the willingness at high rpms. (Angled rod that drives the piston into the wall, therefore the 2.2 has the longest rod of the Ecotec family...)
#53 vocky
Posted 19 February 2016 - 05:47 PM
it needs a new crank sensor bracket and it also needs cleaning, so it's sat back in the garage until I can find some time to look at it.
#54 vocky
Posted 21 February 2016 - 02:06 PM
I have made a nice new crank sensor bracket from a piece of 10mm billet 6061 aluminium :D
#55 Bargi
Bargi
  • 4,483 posts
Posted 21 February 2016 - 02:27 PM
Oh err missus
#56 Jimmy-Boy
Jimmy-Boy
  • 407 posts
Posted 22 February 2016 - 09:12 PM
Will this be on track in the year? would like to come see!
#57 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 26 February 2016 - 09:50 AM
My 2.0 Saab engine has been no hassle to you at all.
Martin S
#58 vocky
Posted 28 February 2016 - 03:31 PM
which works perfectly and I now have 7650rpm to play with rallly
Mapping always seems to make my vx quieter :huh:
Damn cold out there today, had to pull into a layby and put the soft top on, it quickly got rather toasty with my tweaked heater kicking out loads of heat  :wub:
#59 Nev
Posted 28 February 2016 - 04:13 PM
Woooaaah, are you saying you've been driving it ?!
#60 vocky
Posted 28 February 2016 - 06:32 PM
It has done at least 400 miles in the last year Mr Nev :blush:
Well okay 60 miles were on the rolling road and it must have been at least a 40 mile round trip there and back, so 100 miles in one day :P
