Itbs?
50 replies to this topic
#21 stu8v
stu8v
  • 745 posts
Posted 02 May 2016 - 08:09 PM
I cant understand the logic of using Webcon when there is so many more user friendly ecu's available, such as DTA, Emerald, Omex or Canems.
#22 slindborg
Posted 02 May 2016 - 08:14 PM
The only thing you "have" to buy from them is the inlet manifold for the dcoe to z22 bit. The rest is open season IMHO
#23 The Batman
Posted 02 May 2016 - 08:31 PM
I imAgine it's because a loom is off the shelf which makes life easier
#24 stu8v
stu8v
  • 745 posts
Posted 02 May 2016 - 08:33 PM
Manifolds can be made easily.
I've made my own before,
Lotus ITB's onto Pug 306 gti6 engine, not DCOE pattern....
#25 TheHood
TheHood
  • 1,036 posts
Posted 02 May 2016 - 08:34 PM
Hindsight is a wonderful thing 😀 The closed ECU was part of a complete kit and since I had no interest in calibrating it myself, I didn't think it would be an issue. I've talked to 3 of the 4 companies you mention and 2 of them are even quite positive about using the stupid z22se crank trigger pattern and worse case for Stack temp display is some kind of microcontroller.
#26 techieboy
Posted 02 May 2016 - 08:35 PM
Exactly. If you want a simple bolt-on kit instead of cocking about digging up bits and pieces, various bike carbs plus a cable operated pedal and an ECU to run it all , then Webcon is the only option available.
#27 siztenboots
Posted 03 May 2016 - 06:26 AM
The new webcon alpha 5 is a joy to use and I'm happy to remap on that.
#28 slindborg
Posted 03 May 2016 - 10:19 AM
Is it "open" now?
if so then atleast they have joined 1999 :lol: :D
#29 vocky
Posted 03 May 2016 - 11:29 AM
For the itb's to work well it's worth getting a decent exhaust 2.5" and manifold. Then you want cams/springs and the head porting and skimming to increase compression. While the head is off fit improved rods for reliable high rpm. You will then have 220 ish Bhp and around 170 ft/lb. not sure on costs but not cheap maybe 4-5k (not including the exhaust and manifold) depending on how much work you can do yourself and the current cost of the itb kit.
this pretty much sums up the ITB route   I am unsure how much the Webcon ITB kit costs these days. It certainly will be over £2.5k and coupled with a good full exhaust at £1.5k means you have then spent £4k without even touching the engine.   Stage 2 or 3 cams, better valve springs and raising the CR to 11:1 works very well on the ITB engines. I would also advise to fit a 4.17 final drive gearbox - code SG
So £6-7k including the engine?
probably around that figure :mellow:
However the question really should be ... is it worth spending all that to go ITB :unsure:
Oh yeah :D
you simply cannot beat the sound they produce  :wub:  :wub:  :wub:
#30 Raptor
Raptor
  • 942 posts
Posted 03 May 2016 - 02:31 PM
Oh yeah :D
yep great sound.
They really need to get this  Pro5 ECU working on our kit.
Also, if you value your credit card privacy, just do not order anything from the Webcon website.  Just don't :( :(
Edited by Raptor, 03 May 2016 - 02:32 PM.
#31 siztenboots
Posted 03 May 2016 - 02:40 PM
I think Mark had some issues with the tacho input on his stack , or the limited scale, so runs a standalone guage.
#32 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 03 May 2016 - 02:48 PM
  Lastly, are you thinking of selling an ITB'd car soon.   Thank you :)
One could be for sale soon .a real gem on a new engine by vocky special hand s And does it goes ...yes and no oil use either Just fitting two new track road end ball joint tomorow with a new geo.. Full service history as well from day one ...
#33 Raptor
Raptor
  • 942 posts
Posted 03 May 2016 - 02:49 PM
so I assume that needs Webcon to resolve?
#34 siztenboots
Posted 03 May 2016 - 02:57 PM
Marks loom is non standard, so we think too much current fried the stack and a couple of other cheap chinese tachos , as it was the gear shift indicator light, not a PWM signal expected.
#35 fiveoclock
fiveoclock
  • 9,453 posts
Posted 03 May 2016 - 02:58 PM
[quote name="Raptor" post="1857758" timestamp="1462286997"]
[quote name="siztenboots" post="1857755" timestamp="1462286434"]
so I assume that needs Webcon to resolve?  [/quote]
No. Webcon said the only reason I had a problem was that my set up was one of the first they did and they hadn't standardised the loom. I could have got it to work by changing some wiring but went for an aftermarket Spa tacho that logs max revs and has built in shift lights and other fancy sh*t. It's just the temp gauge that won't work.
#36 siztenboots
Posted 03 May 2016 - 03:00 PM
temp gauge should be possible to interface to , the sender should be standard negative temperature coefficient type
#37 Exmantaa
Posted 03 May 2016 - 03:46 PM
Stack temp gauge works with some weird PWM signal and not that easy with the temperature NTC sensor. We use a small PIC board  with a look-up table. Perfect as long as it worked. (probably a voltage supply issue, needs sorting but low prio...)
Or use a secondary temp gauge...
#38 TheHood
TheHood
  • 1,036 posts
Posted 03 May 2016 - 04:37 PM
Any wideband support?
#39 slindborg
Posted 03 May 2016 - 06:51 PM
Stack temp gauge works with some weird PWM signal and not that easy with the temperature NTC sensor. We use a small PIC board  with a look-up table. Perfect as long as it worked. (probably a voltage supply issue, needs sorting but low prio...) Or use a secondary temp gauge...
The Pwm feed to the dash is non linear which is amazingly annoying :lol:
#40 gaffer1986
gaffer1986
  • 4,408 posts
Posted 03 May 2016 - 06:53 PM
Don't underestimate the importance of an "open" ECU even if you're not interested in messing about with the calibration. Mine hasn't turned a wheel in 18 mths, mainly because various small niggles that could easily be solved with ECU access mean a trip on a trailer to Northampton and because I've lost the love I CBA.
What colour is your car you CBA with?
    Google (1)
