Lotus 2 11 Front Upper Arms
25 replies to this topic
#21 Spitfire Engineering
  • 755 posts
Posted 13 August 2017 - 09:39 AM
Do the lotus 211 front arms offer much more camber over standard? I am trying to decide whether to buy these or the eliseparts steering arms for more front camber
Are you in a rush?
#22 Tibbles Stryker
Tibbles Stryker
  • 1,941 posts
Posted 17 August 2017 - 07:55 PM
I run the EP arms on mine, my camber is I think the best compromise now between braking  , damper setting for anti-dive and tyre performance.   If you don't have the 1" arb fitted, I would do that first.
Do these really make that much difference?
#23 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 17 August 2017 - 08:12 PM
Which?
#24 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 23 October 2018 - 03:35 PM
Track width of the VX220 is 1450mm and for exige V6 it´s 1453mm both are using front Wheels with ET26
How can then the Control arms be 15mm wider both sides on the exige V6?
Or is this the wrong information? This is what I can find online.
Or can someone confirm the V6 arms are actually longer?.
Anyone know where you can buy used front V6 arms?
Br, Per
#25 2-20
2-20
  • 1,317 posts
Posted 23 October 2018 - 06:53 PM
I think your figures are wrong.
111r front track width is 1457 and then
Compared to the S2 the Exige V6 has a 70mm longer wheelbase to accommodate the new engine, 25mm wider front track and 38mm wider rear track.
#26 2-20
2-20
  • 1,317 posts
Posted 23 October 2018 - 07:29 PM
Please compare the track rod end size between exige ans exige S.
Why would they change this part between the 2 models.
I think that only the wishbone length can justify the difference.
