Brands Gp Circuit Lot 4Th May
any fancy it?
120 replies to this topic
#101 PaulCP
PaulCP
  • 6,066 posts
Posted 06 May 2017 - 08:41 PM
Depends in which way the cat is knackered. If it collapses and the internals don't blow out through the exhaust then it will knacker the engine since the exhaust gasses will have limited scope for passing through. However, you will know if this is the case since the power will also be drastically reduced.
#102 JG
JG
  • 13,617 posts
It showldn't injest it on the overun, but that is the small risk you run.
#103 pete-r
pete-r
  • 2,771 posts
Depends to be honest on 'how' it fails. If the cat blows out in pieces then no, if the material lodges in the pipe and blocks it you'll potentially damage the motor.
#104 The Batman
Posted 06 May 2017 - 08:49 PM
Ask MartinS he killed his piston rings by running a dead cat But as above if the cat is disintegrating and falling out then it will probably be ok...
#105 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 06 May 2017 - 08:51 PM
I think the map killed both.
#106 The Batman
Posted 06 May 2017 - 08:57 PM
Hmm at a wild guess I reckon map killed cat and cat killed rings
#107 Zoobeef
Zoobeef
  • 11,103 posts
Posted 06 May 2017 - 09:03 PM
Ithink the map was rich, bore washed the cylinders and melted the cat.
#108 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 06 May 2017 - 09:18 PM
Thanks chaps. From the symptoms (which are very similar to Dan r's) I'm guessing the cat is collapsing - not breaking down and being blown out. New cat time. :)
#109 pete-r
pete-r
  • 2,771 posts
Posted 06 May 2017 - 09:26 PM
When's the mot due ;) Hashtag smashthatcatout!
#110 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 06 May 2017 - 09:35 PM
thumbsup August. But if I'm doing that I might as well put a new one in...
#111 JG
JG
  • 13,617 posts
Posted 06 May 2017 - 09:50 PM
oh yeah i forgot about that one.
now i remember why i was worried when mine made a nasty noise, see other thread.
#112 siztenboots
Posted 07 May 2017 - 08:06 AM
The zenos?
#113 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 07 May 2017 - 10:40 AM
The zenos?
Crashed.
...and a 911.
#114 fiveoclock
fiveoclock
  • 9,453 posts
Posted 07 May 2017 - 11:41 AM
The zenos?
Crashed.
Good luck getting parts for that
#115 CHILL Gone DUTCH
Posted 07 May 2017 - 05:08 PM
Was it mapped on a RR
#116 CHILL Gone DUTCH
Posted 07 May 2017 - 05:09 PM
Drill the current cat out and get a new pipe made up for not with a cheap cat ( just for mot )
#117 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 08 May 2017 - 02:34 PM
My piston rings were not ever killed by cat failure, they hadn't bedded in properly and glazed the bores as I was told to run it in over a 1000 miles with regular oil swaps whereas I should have been told to run it in over 100 miles in a totally different way.
I had 3 cat failures in all, one due to excess oil when the rings didn't bed in, two due to excess use (not by me) on rolling roads as they don't get cooled enough.
Its rare a cat will block totally but its not a great idea to run around with it if it is potentially blocked.
If you have to fit a new cat, the best (and cheapest) are ones off a vx turbo. The Dutch have them running upto 360 bhp I belive and mine was running 290 at the end with one of those .
When swapping the belt, make sure to 'not' buy good ones. I had lots of trouble with squeal from Conti ones but the cheap and nasty ones from local car spares places were always good.
Martin S
Edited by MartinS, 08 May 2017 - 02:38 PM.
#118 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 08 May 2017 - 10:14 PM
Thanks for sharing the info Martin, much appreciated thumbsup
#119 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 09 May 2017 - 07:57 AM
Its most likely the flexi broken if there are bits inside rattling around.
Martin
#120 Bootdog
Bootdog
  • 556 posts
Posted 11 May 2017 - 11:11 AM
Foxy, there is a spare belt "in a box" that came with the car - that belt doesn't squeal. The batman fitted the squeaky one first, then changed it to the spare "in the box", but when I got the alternator changed, the garage put the squeaky one back on...
Good to see the car back out where it belongs - I loved Brands, never got a chance to try the GP layout, one of my best TDs was there in the rain with cars spinning out all over the place.
