2.4 Litre 1900 Harrop Build
428 replies to this topic
#321 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 04 March 2017 - 11:20 PM
Didn't know CS did a 4 paddle clutch. Will have to look into this 👍
#322 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 05 March 2017 - 12:03 AM
low rpm is really good drives well and clutch is really good its allot better than i thought it would be so all posatives so far ;-) if weather is good tomorrow will go out for a drive get the first 100 miles done and change the oil and filter ,its strange putting crap cheap oil in it to bed everything in lol
No on/off feeling with your clutch??? Shifting down was horrible with me!
#323 Nev
Posted 05 March 2017 - 05:43 AM
It's just a Helix clutch.
#324 CHILL Gone DUTCH
Posted 05 March 2017 - 08:43 AM
Try and keep it in closed loop so it's using lambda data And please get a log file done
#325 CHILL Gone DUTCH
Posted 05 March 2017 - 08:52 AM
If you put it in fuel learning it will lock it in to closed loop but you will have to becareful to allow engine and lambda to cool down between WoT runs What rpm are you maxing out at the moment while running in
#326 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 05 March 2017 - 09:00 AM
No the bite is right at the top in a different place but other than that very drivable  ,on first drive i was getting ready for a very harsh bite   but isn't that bad unless it needs to bed in more perhaps . Havnt given it any load yet
#327 CHILL Gone DUTCH
Posted 05 March 2017 - 09:02 AM
The car will run in closed loop under low load conditions automatically But again a log will really help us figure out how far the fueling is out and give plenty of data for whennyou move up the Rev range
#328 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 05 March 2017 - 09:03 AM
Its pissing down here so properly will not be going out today  , I didn't rev over 4000 rpm just took it around the block a couple of times .
#329 CHILL Gone DUTCH
Posted 05 March 2017 - 09:29 AM
Might be a bit early ATM but if you can't do anything upload your current map from the car The fuel trims on the general page might of already started to change give us some indication of how much extra fuel your setup is using The good thing about pro version it's possible to use wideband for fuel control
#330 Nev
Posted 05 March 2017 - 12:07 PM
Rain is such a pain the arse isn't it! LOL
#331 Exmantaa
Posted 10 March 2017 - 05:32 PM
How's the running in going?
(Don't baby it around; your rings need some loading to properly seat... poof)
Edited by Exmantaa, 10 March 2017 - 05:41 PM.
#332 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 10 March 2017 - 05:43 PM
Only done 80 miles but will do some more the weekend ,will start giving it some stick .
All seems good though and its just so hard not to floor it in every gear   ;)  rallly  :o
Edited by leevx2.2, 10 March 2017 - 05:45 PM.
#333 FLD
Posted 10 March 2017 - 05:45 PM
Come on Lee. We're all desperate to see this beast on the red line!
#334 CHILL Gone DUTCH
Hows it feeling
#335 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 10 March 2017 - 05:47 PM
Hows it feeling
low end feels really drivable even with 4 paddle  clutch, will go out early sat or sun for some Fuel  learning and fun
#336 CHILL Gone DUTCH
Posted 10 March 2017 - 05:50 PM
LOGS
#337 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 10 March 2017 - 05:52 PM
yes i will ;-)  been a busy week and the weekend is the same
#338 Exmantaa
Posted 10 March 2017 - 06:59 PM
Wel, a little flooring is good. :happy:
Lots written on proper engine bedding-in procedures, but basically being the worst driver with alternating quick acceleration/decelleration sprints on b-roads should should do the trick quickly. Just keep a log running to spot any knock.
(ps; like the new look  thumbsup )
#339 oakmere
oakmere
  • 2,143 posts
Posted 10 March 2017 - 10:50 PM
50 miles on and off the throttle on semi synthetic, then a few hundred miles fully synthetic being quite sensible job done. This was on std prisons and rings though. Not sure all this mineral oil running is is nessary any more?
#340 turbo2015
turbo2015
  • 566 posts
Posted 17 March 2017 - 04:54 PM
lee's future was predicted in 2015, on a who will be the 1st by bargi
http://www.vx220.org...-will-be-first/
