P1635 And 1271 With No Throttle Response
#41
Posted 10 January 2017 - 03:37 PM
#42
Posted 10 January 2017 - 05:21 PM
#43
Posted 10 January 2017 - 06:13 PM
#44
Posted 10 January 2017 - 06:55 PM
#45
Posted 10 January 2017 - 08:13 PM
#46
Posted 10 January 2017 - 08:14 PM
#47
Posted 10 January 2017 - 08:17 PM
can you measure the voltages at the pedal
#48
Posted 10 January 2017 - 08:28 PM
OPCOM has a throttle test function where you can watch the pedal signals.
#49
Posted 10 January 2017 - 08:54 PM
I'd like to, doesn't look like I can back-probe the connector? Can you advise a way to do it? Basically the ECU runs two lines of 5V and gnd to the pedal and the pedal has two potentiometers which send back the voltage from the pedal is what I have learned. The ECU then looks at these two voltages and goes either "they look right" or "Oh sh*t! They don't correspond so I'm gonna cut the voltage to the throttle body. Also thanks FLD, my OPCOM comes tomorrow so I'll make sure I use that function.can you measure the voltages at the pedal
#50
Posted 10 January 2017 - 08:57 PM
opcom will only read the return voltage at the ecu
you need to no what the voltage are at the pedal so you know if its the return wires or the potentiometers or even the feed wires to the pedal
ie
make sure the return voltages at the pedal are the same at the plugs and ecu
Edited by CHILL Gone DUTCH, 10 January 2017 - 09:06 PM.
#51
Posted 10 January 2017 - 09:17 PM
As said; the throttle pedal has 2 independent potmeters; each with it's own reference ecu ground and reference +5.0v. 1 potmeter goes up while the other voltage goes down with throttle input.
So you have 6 wires; 2 x +5.0v, 2x ecu ground and 2 x potmeter signal:
X3 - black plug (have to check which pin does what, but think 3 & 6 are pot signals)
pin 1 = ye (throttle pedal) pin 2 = gn (throttle pedal) pin 3 = bu (throttle pedal) pin 4 = bk (throttle pedal) pin 5 = wh (throttle pedal) pin 6 = bn (throttle pedal)
https://www.speedste...e Z22SE - 1.pdf
With ignition on (don't press the pedal while switching on), my pedal voltages read:
No pedal input => signal A = ~1.0v, signal B = ~4.6v
WOT pedal => signal A = ~4.1v, signal B = ~3.1v
Edit;
So measure with your multimeter grounded to the ecu outside metal and ignition on:
- Search for the 2x 5.0v reference voltage pins
- Search for the 2x reference ecu ground pins. (check there is no resistance to ecu ground)
- Measure both pedal signal pin voltages; both with no throttle input and WOT pedal input. These should measure something similar to my voltages.
Edited by Exmantaa, 10 January 2017 - 09:22 PM.
#52
Posted 10 January 2017 - 09:40 PM
from my old notes:
X3 connector (black 13 pin) Pin #
1 Pedal sensor 2 Low ref (ecu ground) 2 Pedal sensor 1 5V ref 3 Pedal sensor 1 Signal 1 4 Pedal sensor 1 Low ref (ecu ground) 5 Pedal sensor 2 5V ref 6 Pedal sensor 2 Signal 2
#53
Posted 10 January 2017 - 09:41 PM
Cheers for the clarification there. Only measured with no throttle input, got the right reading for APP sensor 2 but APP sensor 1 seemed to show something completely wrong or an open circuit. Need to do a test with a friend pressing the gas pedal to WOT but I'm thinking APP sensor 1 pot is shaggedAs said; the throttle pedal has 2 independent potmeters; each with it's own reference ecu ground and reference +5.0v. 1 potmeter goes up while the other voltage goes down with throttle input. So you have 6 wires; 2 x +5.0v, 2x ecu ground and 2 x potmeter signal: X3 - black plug (have to check which pin does what, but think 3 & 6 are pot signals) pin 1 = ye (throttle pedal) pin 2 = gn (throttle pedal) pin 3 = bu (throttle pedal) pin 4 = bk (throttle pedal) pin 5 = wh (throttle pedal) pin 6 = bn (throttle pedal) https://www.speedste...e Z22SE - 1.pdf With ignition on (don't press the pedal while switching on), my pedal voltages read: No pedal input => signal A = ~1.0v, signal B = ~4.6v WOT pedal => signal A = ~4.1v, signal B = ~3.1v Edit; So measure with your multimeter grounded to the ecu outside metal and ignition on: - Search for the 2x 5.0v reference voltage pins - Search for the 2x reference ecu ground pins. (check there is no resistance to ecu ground) - Measure both pedal signal pin voltages; both with no throttle input and WOT pedal input. These should measure something similar to my voltages.
#54
Posted 10 January 2017 - 09:45 PM
If something measures wonky there; look upstream towards the pedal.
Could be faulty pedal or Pedal connector. There were cases reported of a chafed wiring loom to the gearchange mechanism inside the centre console...
Ow, bit hard to do, but while measuring with moving pedal input; check for a gradual change in voltages.
Edited by Exmantaa, 10 January 2017 - 09:48 PM.
#55
Posted 10 January 2017 - 09:50 PM
Good point, if it's not the pedal or connector I reckon I'll be somewhere between the pedal connector and loom of doom, which is the wiring that runs up the centre of the cabin under the centre console and that passenger and driver foot space "divider"?If something measures wonky there; look upstream towards the pedal. Could be faulty pedal or Pedal connector. There were cases reported of a chafed wiring loom to the gearchange mechanism inside the centre console... Ow, bit hard to do, but while measuring with moving pedal input; check for a gradual change in voltages.
#56
Posted 10 January 2017 - 09:55 PM
Yep; centre console is suspect then, as the wiring loom is ty-wrapped to metal and very close to moving parts. Inside the footspace divider the loom is not so vulnerable.
#57
Posted 10 January 2017 - 10:00 PM
This pic shows the 2 pedal voltages going up and down. (look to the good left graph, as MartinS had some "throttle issues" back then...)
Edited by Exmantaa, 10 January 2017 - 10:01 PM.
#58
Posted 18 January 2017 - 12:48 PM
#59
Posted 18 January 2017 - 01:51 PM
This thread is very useful thanks!
I have what appears to be an identical problem. Planning to have a good check of all the connectors and loom over the next few weeks!
#60
Posted 19 January 2017 - 12:55 PM
