Anybody Tried The Holley Hydramat For Fuel Starvation Issue?
fuel starvation
70 replies to this topic
#21 CHILL Gone DUTCH
Posted 27 January 2017 - 03:15 PM
Would the matt have to go all the way to the end of the tank as it seems to absorb the fuel and in effect give you my fuel than the canister can hold
#22 The Batman
Posted 27 January 2017 - 03:17 PM
You would be only able to fit a small mat
Here's is a photo
#23 CHILL Gone DUTCH
Posted 27 January 2017 - 03:18 PM
What are we looking at there joe
#24 The Batman
Posted 27 January 2017 - 03:21 PM
This is where the fuel pump canister goes so the space is quite limited if you wanted to fit one of those mats Not sure if it's stepped actually I will go check
Edited by The Batman, 27 January 2017 - 03:24 PM.
#25 CHILL Gone DUTCH
Posted 27 January 2017 - 03:22 PM
ah so the tank is stepped to take the canister
#26 The Batman
Posted 27 January 2017 - 03:24 PM
Na that is the bottom of the tank, the baffle plate allows fuel to come down the sides into the pump section
#27 smiley
Here Frank (exmantaa) reported that his spitfire pump drained the pro alloy tank completely dry (first hand info)
http://www.speedster...inpumpe/&page=5
Funny how these things affect each other.
#28 The Batman
Posted 27 January 2017 - 03:25 PM
So would adding a couple extra one way valves help the situation then? As if so I can get the design adapted :)
#29 The Batman
Posted 27 January 2017 - 03:29 PM
Ok so it's not stepped
But my s1 tank is a fair bit different to a vx tank the baffles are different
Look how minging that tank is :lol: :lol:
#30 smiley
Posted 27 January 2017 - 03:31 PM
In another topic they mention that oem tank is a few mm tilted, so fuel flows to the pump. (where pro alloy is leveled)
http://forum.opel-sp...pic=35761&st=30
Edited by smiley, 27 January 2017 - 03:32 PM.
#31 The Batman
Posted 27 January 2017 - 03:35 PM
There is a few mm play when fitting the tank so couldn't you just angle the tank with those few mm?
#32 CHILL Gone DUTCH
Posted 27 January 2017 - 03:42 PM
i would say a bigger cannister would be more effective but everything would have limits
#33 The Batman
What's also worthwhile thinking about is if the fuel level sensor is working correctly with the new tank . E.g does the pro alloy baffles make you think you have more or less fuel
Here is a photo of pro alloy baffles
The rest of the tank has anti surge foam in
#34 Nev
Posted 27 January 2017 - 03:43 PM
When I bought my car off Alex at Pro-Alloy, he mentioned that he was designing the next VX220 fuel tank to have some one way ball valves and a small surge reservoir on the left hand side of the tank. I wonder why this didn't make it to production.
The Holly hydromat looks a good solution TBH, so long as you can hook it up to the exiting fuel pump.
Edited by Nev, 27 January 2017 - 03:45 PM.
#35 WrightStuff
WrightStuff
    i am sheldon cooper
  • 2,238 posts
Posted 27 January 2017 - 03:46 PM
Mines fine for all the tracks I've been to except zandvoort going up the hill just after the long left handed ( still turning left up the hill )
It's fine if I keep 11 litres + in the tank
GST 450-k pump here
Same here.
I get starvation going up the hill following the left hander at turn 3, and on the straight after the left hander at turn 9.
#36 CHILL Gone DUTCH
Posted 27 January 2017 - 03:49 PM
a angled baffle which only goes half way up the tank would be a good idea so the fuel can still get in to the area easily and not back to the right hand side of tank easily
#37 Nev
Posted 27 January 2017 - 03:54 PM
I agree, a simple solution like that would suffice. I'm not sure why it hasn't been done TBH.
Myself and a friend may be making a new fuel tank for his VX220 soon. I'll start a blog if we do.
Edited by Nev, 27 January 2017 - 03:55 PM.
#38 The Batman
Posted 27 January 2017 - 03:57 PM
How would a angled baffle only going half way up help when the tank is really low on fuel?
#39 Nev
Posted 27 January 2017 - 04:00 PM
It acts as a flow restriction, trapping a gallon or so of fuel in the left side. With a few small holes in it to allow the level to equalise between the left and right side of the baffle when driving in a roughly straight line.
It's a standard design for oil sump baffles etc and reduces the fabrication complexity, cost and and risk of failure of either a hinge or ball valve.
Edited by Nev, 27 January 2017 - 04:03 PM.
#40 The Batman
Posted 27 January 2017 - 04:04 PM
The original vx baffle allows fuel to come round either side (like pro alloy) along with a big hole in the top half of the section and smaller holes in the bottom Which is why I'm struggling to see why a half angled baffle plate would work better
