Aquamist Meth Injection Fitted & Results
61 replies to this topic
#1 scw02102
scw02102
  • 1,581 posts
Posted 17 February 2017 - 09:39 PM
Well after a long time I have finally got round to installing and testing my Meth injection on my VXT
Thanks to Steve (Crabash) for spec-in my kit and all his help.
Im not going into details about the bhp as its been on two different dyno in a week, both have different readings (20bhp difference between the two) and as I always said dyno readings are crap when it comes to power figures just good pub talk. I use a base reading then tuned from that to see what gains could be made but more importantly just set up the fueling for the meth and check those vital inlet temps
Running 50/50 meth with 2 jets on the lowest setting my inlet temp on Courtney dyno never went over 41C and today on a different dyno never got over 46C
Bear in mind that on the same dyno my was hitting 85C so what a massive drop in inlet temps,
So does it work?
Yes!
Is it worth it?
Yes, especially if you can fit it yourself as its fairly cost effective, If your an idiot like me you have to pay others which can work out expensive but hey its cheaper than a Charger Cooler which cost best part of £2.5k fitted
On the road?
Well, day one I couldn't hit more than 30C and today peaked at 36c! Again bear in mind my car normally hit 70-85C so very pleased.
Playing with the map we managed to gain 30bhp using the meth and apparently more can be had using a 80mm MAF
How quickly does the tank empty?
Well I could only fit a 3Litre tank in the boot, for normal road use I hardly used any, did about 6 hours driving mainly motorway and only used 1 litre or maybe less.
I must admit on the dyno today I used 2 litres, so on a full track day I expect to use 3-4 litres but again will depend on the size of your nozzles and rate you are pumping.
Oh and the fail safe with Aquamist defo works, I ran out of meth. The system told me and gave me no boost. So I just drove home like a granny, topped up and boom, 20PSI of boost was back :)
Edited by scw02102, 17 February 2017 - 09:40 PM.
#2 The Batman
Posted 17 February 2017 - 09:57 PM
awesome results there :)
when you say you hit 70/85'c is that in this current temperature (below 10'c outside)?
#3 scw02102
scw02102
  • 1,581 posts
Posted 17 February 2017 - 10:17 PM
70c in the winter and 85 in the summer on the road My inlet temps used to climb like mad. Last Jan in the winter (cold) it was hitting 85c on the dyno but air flow is always restricted in a dyno garage wth a large fan Same dyno today similar weathe too, in fact arguably warmer today.
#4 The Batman
Posted 17 February 2017 - 10:18 PM
What "stage" are you and on standard IC?
#5 scw02102
scw02102
  • 1,581 posts
Posted 17 February 2017 - 10:22 PM
Stage 3 MMG intercooler The car is stage 4 spec but meth used instead of the cc but the inlet readings show it's similar to cc temps but can use the additional octane from the meth.
#6 The Batman
Posted 17 February 2017 - 10:28 PM
interesting that you have a stage 3 mmg intercooler... wherent these the ones that where meant to be as good as a chargecooler?
 my mapper now has water/meth injection on his itb car rallly
#7 scw02102
scw02102
  • 1,581 posts
Posted 17 February 2017 - 10:41 PM
I can guarantee you in real life they are no where near as good as a cc The recovery time from heat soak is better than standard though, suited for a standard or stage 1 vxt Anything else u need a cc or meth kit in my opinion
#8 rueda
rueda
  • 124 posts
Posted 17 February 2017 - 11:13 PM
Nice ! ;)
Any pics of the setup ? Where are the pump, tank and the nozzles ?
Edited by rueda, 17 February 2017 - 11:13 PM.
#9 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 17 February 2017 - 11:58 PM
Good output. Bet you can feel the difference now
Edited by mbes2, 18 February 2017 - 12:00 AM.
#10 siztenboots
Posted 18 February 2017 - 08:42 AM
Post up the dyno graphs from both
#11 TFD
TFD
  • 607 posts
Posted 18 February 2017 - 12:36 PM
On the road?
You mean hitting 70-85 just cruising around on the highway or spirited B-road fun?
I got 45C on a 19C day while cruising 120km/h.
#12 scw02102
scw02102
  • 1,581 posts
Posted 18 February 2017 - 05:26 PM
dyno graphs think I binned them lol
I didnt really do much testing at CS but it left there with a figure and two days later in the same if not warmer conidtions it make 20bhp less. Just shows how different rollers have different calculations. Im not saying CS are over inflating but they were defo higher readings but dont want to get into rolling road battles. I must say CS were very professional and did a great job with the install, plus John was very useful/friendly
no crusing temp was ambient plus 10c or 15c but once you hit the throttle hard it just climbs in seconds from 25C to 70+ in just 2nd and 3rd gear
Edited by scw02102, 18 February 2017 - 05:31 PM.
#13 scw02102
scw02102
  • 1,581 posts
Posted 18 February 2017 - 05:28 PM
Will post some pics of the install when I get some time, and Yes mark, its bonkers now! Defo dont need any more power thats for sure.
Think im finally satisified
#14 ufods
ufods
  • 235 posts
Posted 18 February 2017 - 08:18 PM
....and WI is not only cheaper....it seems to be lighter than a water - air charge cooler. Of course depending on the amount if water in the tank.
#15 scw02102
scw02102
  • 1,581 posts
Posted 23 February 2017 - 08:51 PM
Forgot to photograph the ECU unit but that is tidily installed in the seat holder behind my seat
#16 NOSBandit
NOSBandit
  • 271 posts
Posted 23 February 2017 - 09:04 PM
So what power and torque are you running now on that setup? Sent from my SM-G935F using Tapatalk
#17 The Batman
Posted 23 February 2017 - 09:08 PM
Looks good, did you have to move the tmap sensor because of the setup or was that already done?
#18 Ivor
Ivor
  • 2,180 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 23 February 2017 - 09:10 PM
Is this an off the shelf kit? IE can it be purchased in one or do you have to have a shopping list? Seriously interested in doing this...
#19 CHILL Gone DUTCH
Posted 23 February 2017 - 09:14 PM
http://www.aquamist-...sing-pwm-valve/
#20 Ivor
Ivor
  • 2,180 posts
    and now bees
Posted 24 February 2017 - 07:19 AM
thanks Chill
