Aquamist Meth Injection Fitted & Results
61 replies to this topic
#21 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 24 February 2017 - 07:47 AM
Great results 😎 Ivor, Steve aka Crabash knows more than most ref the W/I and completed a few proven setups. I would drop him a PM and always very helpful, may be able to supply kit required DG
#22 siztenboots
Posted 24 February 2017 - 11:51 AM
the new bmw m4 uses a new bosch WI system , I prefer very high pressure chemical cooling , pure water , rather than meth mixes.
#23 fezzasus
Posted 24 February 2017 - 12:59 PM
Depends if you're knock limited
#24 scw02102
scw02102
  • 1,581 posts
Posted 24 February 2017 - 11:05 PM
Looks good, did you have to move the tmap sensor because of the setup or was that already done?
I moved the tmap sensor as I wanted the ECU to see the lower inlet temps and as std it stuck on the intercooler it wont see the new temps
I had a bigger jet fitted before the intercooler and a smaller one after the IC
Then the Tmap was bossed into the tophat to read the lower inlet temps
Then allowed me to tweek the map to use the extra octane and lower inlet temps
#25 scw02102
scw02102
  • 1,581 posts
Posted 24 February 2017 - 11:11 PM
Is this an off the shelf kit? IE can it be purchased in one or do you have to have a shopping list? Seriously interested in doing this...
Yeah the link chill added was the kit Remember to add a water bottle too and the aquamist is too tall for the boot so u might have to buy another brand. Also worth noting the nozzle size and locations can and will make a difference to the performance.
#26 The Batman
Posted 24 February 2017 - 11:18 PM
  I moved the tmap sensor as I wanted the ECU to see the lower inlet temps and as std it stuck on the intercooler it wont see the new temps   I had a bigger jet fitted before the intercooler and a smaller one after the IC  Then the Tmap was bossed into the tophat to read the lower inlet temps   Then allowed me to tweek the map to use the extra octane and lower inlet temps
Setup sounds perfect thumbsup
#27 Ivor
Ivor
  • 2,224 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 25 February 2017 - 07:44 AM
If it's too tall for the boot where have you put it!
#28 Ivor
Ivor
  • 2,224 posts
    and now bees
Posted 25 February 2017 - 07:46 AM
Or are you not using that kit ?
#29 CHILL Gone DUTCH
Posted 25 February 2017 - 08:37 AM
I use the 2.2 litre window washer tank But have see the tank mounted behind seats or I've seen people mounting them in the sill just in front of thecear So really it can be mounted anywhere
Edited by CHILL Gone DUTCH, 25 February 2017 - 08:38 AM.
#30 dw1
dw1
  • 3,043 posts
Posted 25 February 2017 - 09:28 AM
Will post some pics of the install when I get some time, and Yes mark, its bonkers now! Defo dont need any more power thats for sure.   Think im finally satisified
Always great to see owners really happy with their own car. (Yours looks the dogs danglies thumbsup)
#31 export001
export001
  • 116 posts
  • Interests:If you call constantly breaking the vx then yes
Posted 25 February 2017 - 09:37 AM
i have just perchased a AEM meth kit purely to keep knock down, glad you have proven results, i have a custom charge cooler set up which seems to keep intake temps down to around 30 but im yet to increase from base boost. the meth kit is just to help it when i do turn it up to 1.6 bar, so hopefully see similar results.
#32 CHILL Gone DUTCH
Posted 25 February 2017 - 10:02 AM
To keep knock down ? Surely you shouldn't have knock anyway
#33 export001
export001
  • 116 posts
Posted 25 February 2017 - 10:35 AM
i run a saab b204 engine in my vx220 its the one one to be converted, intake temps can rise dangeruosly quick in them and can trigger fuel cut which seriously can be dangerous as it like a very heavy missfire
#34 scw02102
scw02102
  • 1,581 posts
Posted 26 February 2017 - 09:33 AM
The bottle doesnt come part of the kit, its extra
As the Aquamist bottle is too tall for the boot I just bought another brands meth bottle (3 litres) which was the biggest I could find that would fit in the boot. Maybe a wider lower bottle would work too if you can find such a thing...
#35 scw02102
scw02102
  • 1,581 posts
Posted 26 February 2017 - 09:37 AM
Chill how are you finding the smaller 2.2 tank as I found with mine the fail safe kicked in when the bottle still had about 20% meth remaining. Now this is a good thing so it doesnt suck up air but then does mean that you dont quite get the full 2.2L or 3L in my case.
on the road I hardly use any meth but on the rollers or in your case the track I did use much more
#36 CHILL Gone DUTCH
Posted 26 February 2017 - 12:59 PM
The 2.2 litre header tank shape helps, better than a square bottomed tank I suppose it depends on how much you are injecting plus my second map ( road/ failsafe )just curves the ignition back to a level where I was prior to water injection My statergy with it was to inject as little as possible just enough to keep things cool AT a recent track day I had enough to do this for over 25 min session I have a stepped rate controlled by my ecu where anything below 40 degree I inject at 80% Anything over 40 degrees I inject at 100% ( which so far quickly drops temps down below 40 ) and anything over 70 degrees injects 120% I also think I may be able to inject even less after some more testing
#37 NOSBandit
NOSBandit
  • 271 posts
Posted 26 February 2017 - 02:32 PM
I use the AEM system with a 50/50 water meth mix on mine and my IAT's barely go over 30 degrees. The system uses the 0.5mm jet and at 20psi boost only runs at 36% duty cycle, the 1 gallon tank lasts for ages. The intake manifold was still nice and cool after a few hours on the dyno. Sent from my SM-G935F using Tapatalk
#38 CHILL Gone DUTCH
Posted 26 February 2017 - 03:26 PM
I also don't start to inject until it reaches 46% duty cycle
#39 CHILL Gone DUTCH
Posted 26 February 2017 - 03:29 PM
I think the meth really has a lot of potential but it was never my intention to use it I don't want to push my block any further Just want to keep things cooler with as little injection of 100% water as possible
#40 NOSBandit
NOSBandit
  • 271 posts
Posted 26 February 2017 - 03:43 PM
I use the AEM controller at it's lowest settings, it doesn't start injecting until the boost goes over 11psi and wouldn't be at a 100% until the boost would reach 36psi. As I only run my boost at 20psi at maximum at the moment, the water meth duty cycle never goes over 36% Sent from my SM-G935F using Tapatalk
