2.4L 1320 Harrop Build
Posted 01 April 2017 - 10:04 PM
Posted 01 April 2017 - 10:11 PM
Posted 01 April 2017 - 10:13 PM
Well does it count that I had the trigger wheel and crank before him 😂Sorry is this a wannabe Lee thread?
Posted 01 April 2017 - 10:17 PM
Engine out
Forgot to add will also be fitting this a brand new f23 gear box 😍
Engine and box will be getting painted in special engine paint. The Ecu is on is also on its way back to me.
Edited by haggi961, 01 April 2017 - 10:19 PM.
Posted 02 April 2017 - 05:39 AM
Amazing how everyone is pushing the boundaries forward. Will this be the 3rd 500+ HP supercharged VX and certainly the first Vexlise!?
I still remember people like JG permanently bleating about how his NA was all anyone could want for a sports car. Of course even he finally wised up over time.
Best of luck, looking fwd to a race off between you and Lee! LOL
Edited by Nev, 02 April 2017 - 05:40 AM.
Posted 02 April 2017 - 06:20 AM
Posted 02 April 2017 - 06:56 AM
Posted 02 April 2017 - 07:22 AM
Posted 02 April 2017 - 08:02 AM
How did you get to find a brand new f23, that's good going
like this one? http://www.ebay.co.u...8wAAOSwo4pYPYr5
Posted 02 April 2017 - 08:15 AM
Your spec appears to be significantly different again to both Lee and Richard. Good to see you guys all doing different things. Will the 1320 puff all the way to 500 BHP?
I find it amazing how a crank designed for 150 ft/lb copes with all the extra torque. Same with the Z20LET cranks too, somehow they all seem to cope. Maybe the OEMs add extra mass to them deliberately to help with smoothness and Euro 4/5. Anyway it's a bonus for us.
@Mods: Wouldn't this thread be better in the projects folder?
Edited by Nev, 02 April 2017 - 08:17 AM.
Posted 02 April 2017 - 08:22 AM
Posted 02 April 2017 - 08:26 AM
What grind cams are you using? "Stage 3" says not much, or you must mean the ZZP LSJ stage 3? (Which are similar to the Comp Blower cam specs...)
Posted 02 April 2017 - 08:37 AM
Posted 02 April 2017 - 09:15 AM
eh? Emission control legislation has nothing to do with crankshaft design, and the extra mass will actually result in a weaker crank due to greater oscillating mass (thus flex).
Generally the bottom end is significantly over spec'ed to cope with worst case knock scenarios.
Posted 02 April 2017 - 09:16 AM
stage 3 NA cams
SC cams are too mild
Posted 02 April 2017 - 09:45 AM
Guess NA only option, would of done this for my old tubby if you could still get them
Posted 02 April 2017 - 11:23 AM
I had a friend who had a Vauxhall V6 engine and he remarked one day that his flywheel had to have extra mass added to it to pass some emissions control (for the USA). Hence I was postulating adding mass to the crank would do similar.
I doubt adding mass to the main bearings would affect things adversely, more surface area for the shells and hence less pressure would presumably extend their life and help reduce the chance it snapped from excessive torque or knock.
Coping with bad knock sounds a very sensible reason for their seemingly huge strength.
Edited by Nev, 02 April 2017 - 11:25 AM.
Posted 02 April 2017 - 01:25 PM
Which set# /grind #?? Comp does not sell "stage" sets... ps; why the Z22SE head ported that is more sensitive to cracking than a sandcast B207 head?stage 3 NA camsWhat grind cams are you using? "Stage 3" says not much, or you must mean the ZZP LSJ stage 3? (Which are similar to the Comp Blower cam specs...)
Posted 02 April 2017 - 01:38 PM
compcams 113400
http://www.compcams....?csid=1083&sb=2
z22se head only because it's already been ported.
Posted 02 April 2017 - 02:00 PM
