2.4L 1320 Harrop Build
113 replies to this topic
#41 Rosssco
Rosssco
  • 4,185 posts
Posted 21 April 2017 - 01:56 PM
Because it's a le9 gen 3 block so strong enough for 600 hp straight out the factory.
Slightly interestingly, I've a Gen 2 LE9 block, which isn't sand cast and has liners.
#42 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 21 April 2017 - 04:07 PM
You have a Le5 block which is gen 2. Same as the b207 but a 88mm bore size instead.
#43 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 21 April 2017 - 04:36 PM
So Le9 gen 2.5 or 3 to make it easier. Same block as the A20nft Astra but le9 is 2.4 version.
A Le5 gen 2
And a standard z22se gen 1 looks the same as the Le5 block gen 2. Only difference is the gen 1 has a 66mm deep water channel and the gen 2 has a 104mm deep water channel.
#44 Nev
Posted 21 April 2017 - 06:02 PM
Nice uniform water jacket at the top of the cylinders.
#45 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 21 April 2017 - 06:52 PM
This is what hopefully makes its stronger and no need for liners.
#46 Jocke_D
Jocke_D
  • 407 posts
Posted 24 April 2017 - 11:54 AM
And the Gen 3 liners are cast-in, so no liner change possible...
Aha. Thanks.
Was wondering what to do with my own "new" block. Change liners, honing or boring. But it was a case of apples and pears I guess :)
#47 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 16 May 2017 - 09:58 PM
Everything is all here and done now, except the delivery of my cams 🙈 In the end I've order cat cams as comp had no stock and wasn't planning anytime soon to have stock. Plus they are the most unhelpful people ever 😡
#48 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 17 May 2017 - 09:46 AM
Nearly there Luke the extra torque and power will make it all worth it 😉
#49 alanoo
alanoo
  • 1,324 posts
Posted 17 May 2017 - 12:44 PM
No oil cooler on this block ?
#50 Exmantaa
Posted 17 May 2017 - 01:46 PM
The 2.4 has no oil cooler standard (like the Z22SE). So install a Z22SE oil cooler plate, or better drill and tap 2 new oil cooler connections. (1x return hose and 1x oil pressure sender)
#51 Rosssco
Rosssco
  • 4,185 posts
Posted 17 May 2017 - 02:15 PM
The actual technical literature / blurb for the LE5/9 engine (2.4) states there is no requirement for an oil cooler (being noted as an advantage for efficiency, supposedly), although this is in its original application, not a sports car..
I reused the standard VX220 oil cooler arrangement on my 2.4.
Edited by Rosssco, 17 May 2017 - 02:16 PM.
#52 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 17 May 2017 - 02:58 PM
This is what il be getting done with tapping two holes, so there is no need for the stupid metal oil rings ever again 😁
#53 Nev
Posted 17 May 2017 - 03:10 PM
Haggi, I think you are wise to elect for a good home made oil cooler setup on a big power engine. I have always suspected my oil gets too hot and wish I had a non OEM cooler in mine.
#54 vocky
Posted 27 May 2017 - 01:14 PM
pistons and rods
fitted into block
crank added, it has an internal 5+2 trigger wheel
and the base plate added, also drilled and tapped for the oil pressure switch and oil cooler take off
#55 alanoo
alanoo
  • 1,324 posts
Posted 27 May 2017 - 01:35 PM
Do I spot a specific machining on the pistons to clear out the oil squirters ?
#56 vocky
Posted 27 May 2017 - 05:54 PM
they are JE Pistons and came ready to fit thumbsup
These LE5 oil squirters are the later tube type
#57 vocky
Posted 27 May 2017 - 05:59 PM
balancer delete fitted, then balancer chain and water pump added
modified the sump baffle
sump bolted to block
TTV flywheel aligned and ARP bolts added
Helix Paddle clutch plate and cover aligned and fitted
#58 CHILL Gone DUTCH
Posted 27 May 2017 - 06:06 PM
What are the red circles ?
#59 vocky
Posted 27 May 2017 - 06:07 PM
just to show the crank balancing marks are aligned. They are added to the photo, not the engine :P
#60 CHILL Gone DUTCH
Posted 27 May 2017 - 06:10 PM
thought it would be something like that  ;)
