Ap Rotor Cracks
#41
Posted 25 June 2017 - 03:30 PM
#42
Posted 25 June 2017 - 03:33 PM
And a pic from the other side?
#44
Posted 25 June 2017 - 08:41 PM
#45
Posted 25 June 2017 - 09:07 PM
#46
Posted 25 June 2017 - 09:21 PM
lol
good luck!
#47
Posted 26 June 2017 - 10:26 AM
I would image the problem is due to a combination of:
1. Outside radius of any material will expand/contract the most (particularly as that's the friction surface on a rotor).
2. Not enough meat on the disc to give it adequate strength.
3. Poor casting quality.
My bet is, if you replace them with the same part, the same problem will occur.
Solution: Lotus/Vauxhall OEM brake setup for 10% of the cost, or some other cheap brand OEM setup (which is what I did in the end (Porsche + Alfa for about £350).
Edited by Nev, 26 June 2017 - 10:34 AM.
#48
Posted 26 June 2017 - 10:31 AM
When installing/keeping OEM parts (eg Vauhall brakes) you can be pretty assured that the OEM has done it's best to ensure a minimum of faulty parts. No mass produced car manufacturer wants thousands (or millions) of warrantee claims, so they do their utmost to make things (including brakes) work and last well. If they didn't they'd go bust.
Conversely, 3rd party sellers like AP or whoever don't give a sh*t, as they rarely/don't offer a redeemable warranty.
QED and a lesson to be learnt about the different business models.
Edited by Nev, 26 June 2017 - 10:56 AM.
#49
Posted 26 June 2017 - 12:36 PM
#50
Posted 26 June 2017 - 12:38 PM
can you get a other disc turned to suit the bell
#51
Posted 26 June 2017 - 12:39 PM
The reasons for the outcome are quite obvious, by catching only the outer section of the disk not only has it heated this section causing a large heat differential with the rest of the disk but because the outer section is doing all the work it's temperature will be even hotter than a normal working disk.
With the current setup it's unlikely you will see anything but the same again if you just replace the disks.
Not sure what the problem is though...
Are the disks not matched to the pads in terms of sweep geometry? the entire surface should be swept less a small section in the centre for clearance reasons.
Are the callipers spaced out too far?
Bell/disks too small?
#53
Posted 26 June 2017 - 01:49 PM
#54
Posted 26 June 2017 - 03:02 PM
#55
Posted 26 June 2017 - 03:41 PM
I've got those on my car. Will have to give them a check over
#56
Posted 26 June 2017 - 03:56 PM
Interesting. 4 pots? Maybe a sticky caliper?
#57
Posted 26 June 2017 - 04:02 PM
#58
Posted 27 June 2017 - 01:36 PM
Oh and god those discs are expensive compared to VX standard discs!
#59
Posted 27 June 2017 - 02:33 PM
#60
Posted 27 June 2017 - 03:27 PM
