Vxt Not Starting - Can’T Hear Fuel Pump?
Posted 28 November 2017 - 10:10 AM
Posted 28 November 2017 - 10:16 AM
go to the boot , find the concealed black cover for the fuses and relays ,
try swapping around the grey relays , and yellow fuses
Posted 28 November 2017 - 11:28 AM
The fuel pump fuse is the second yellow 20A one.
Posted 28 November 2017 - 11:34 AM
thanks gents - I'll give that a shot tonight.
Posted 28 November 2017 - 11:47 AM
fuel pump relay should be grey, check the wiring, it has a big and small gauge wire both White with a purple chaser. none of the other relays have that wire colour.
Posted 28 November 2017 - 09:10 PM
Posted 28 November 2017 - 09:31 PM
Posted 28 November 2017 - 10:07 PM
Edited by The Batman, 28 November 2017 - 10:07 PM.
Posted 28 November 2017 - 10:26 PM
I have had same symptoms, twice this year
mine was the big yellow relay in the boot - I removed it, cleaned the terminals with wire wool, then sprayed with electrical contact cleaner - refitted, tried to start car and vroom vroom
Happy days
and to answer the second part of your OP, yes, you turn the key, you normally hear the pump prime and then push the start button, and into life (normally)
If immobilised, you should have a constant red led on the speedo display, when trying to start (mine did) I suspected immob issue when my yellow relay started playing up
Edited by VX DAVE, 28 November 2017 - 10:32 PM.
Posted 29 November 2017 - 11:06 PM
Posted 30 November 2017 - 12:22 AM
The yellow relay is the starter relay, so if its turning over the that should be OK.
Short across the fuel pump relay and see if the pump goes.
Check the loom of doom, as well as the actual connectors being shitty I've seen broken wires there too.
Where abouts are you?
Posted 30 November 2017 - 05:10 AM
Posted 01 December 2017 - 01:31 PM
Posted 01 December 2017 - 01:45 PM
Posted 01 December 2017 - 02:01 PM
Posted 01 December 2017 - 03:32 PM
Yes - thanks! Was planning to check that from your earlier suggestion!(Or the earth ;-))
Posted 03 December 2017 - 02:45 PM
I'm assuming that's the ECU at the back of the engine bay on the let hand side, fixed to the bulkhead.
In which case the casing is definitely earthed
Posted 03 December 2017 - 03:15 PM
next step... get connectors off and see whether the loom's providing power
