Vxt Not Starting - Can’T Hear Fuel Pump?
66 replies to this topic
#41 siztenboots
Posted 15 December 2017 - 08:48 AM
correct same wire
#42 NDT
NDT
  • 351 posts
Posted 15 December 2017 - 12:12 PM
it would crank, just wouldn't start
very helpful - thanks
#43 NDT
NDT
  • 351 posts
Posted 15 December 2017 - 12:13 PM
Zoobeef, sizetenboots - very helpful stuff. thanks. Going to try bridging the immobiliser terminals and see whether we get some comms.
#44 vocky
Posted 15 December 2017 - 12:27 PM
you cannot 'bridge' the vauxhall immobiliser system, all you will do is possibly cause damage
It is a single wire from the immobiliser to the ecu which gives the required handshake to make the engine run (X31 - pin 2)
#45 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
  • Interests:Performance cars!
Posted 15 December 2017 - 06:46 PM
When you say its earthed have you tried a jump lead from thr casing to the engine block? Mine looked earthed but was too corroded to contact. All other symptoms identical.
#46 NDT
NDT
  • 351 posts
Posted 16 December 2017 - 03:18 PM
I checked continuity from the earth wire to the block and from the ECU casing to the block.
Both were fine.
#47 NDT
NDT
  • 351 posts
Posted 16 December 2017 - 03:25 PM
thanks.
This came from a Vauxhall diagnostic guide - put a fused jumper wire between 6 and 7 on the immobiliser connector and see whether comms get established.
#48 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 16 December 2017 - 03:53 PM
thanks.
Soooo, whos testing that :D I don't want my immobiliser.
#49 NDT
NDT
  • 351 posts
Posted 16 December 2017 - 04:22 PM
thanks.
Only bridging on the loom side connector, not the immobiliser itself.
Anyway, we'll see if it helps. Or not.
#50 Zoobeef
Zoobeef
  • 11,103 posts
Posted 16 December 2017 - 07:34 PM
Ahh yes I see now!
#51 NDT
NDT
  • 351 posts
Posted 17 December 2017 - 10:18 PM
might be getting somewhere now.
Bridged 6 and 7 on the immobiliser plug so the ECU has a clear path to the diagnostic plug. No joy.
However while checking the pins I found that pins 4, 5 and 6 on the immobiliser plug appear to be joined.
Which is probably not helpful as 4 goes to the battery negative, 5 is power from fuse 7 and 6 goes to the diagnostic plug.
#52 NDT
NDT
  • 351 posts
Posted 30 December 2017 - 10:36 AM
this was a red herring - obviously my crappy test kit.
#53 NDT
NDT
  • 351 posts
Posted 30 December 2017 - 10:43 AM
SOLVED - turned out to be a broken wire near the X3 connector in the loom of doom behind the coolant expansion tank.
My biggest mistake was ignoring a voltage drop on one of the power wires at the SCU connector - I assumed 0.5v different to everything else was ok - it's not!
#54 jayworth2
jayworth2
  • 73 posts
Posted 01 June 2018 - 05:07 PM
Did you check Zoobeef's suggestion of grounding the solinoid part of the fuel pump relay to activate the fuel pump...if the pump then runs its probably be an ECU problem....and I could give you the whole saga of what happened in my case!
I have a similar problem If I put the earth pin on the fuel pump relay to another known good earth the fuel pump will prime & engine will start. Hoping it's only going to be a bad earth somewhere. How will I know if I 'am going to have ECU problems that you had?
#55 siztenboots
Posted 01 June 2018 - 05:26 PM
check continuity of the inertia switch ,
Its inline of the two relays , its only this which breaks the supply to the relay for fuel pump and injectors.
so although the relay maybe be fine , the inertia switch could be open circuit .
#56 jayworth2
jayworth2
  • 73 posts
Posted 03 June 2018 - 10:41 AM
So if i'am grounding pin 85 of the fuel pump relay i'am bypassing fuel cut off switch?  If I use the engine block as earth I get power at all relays but if I use the white / purple wire at fuel pump relay pin 85 as an earth I only get very small readings on all relays.
#57 siztenboots
Posted 03 June 2018 - 10:49 AM
yes 85 , when put to ground will energise the relay , but the 12v supply that it switches comes from the thick 2mm white-violet wire . This wire is from the FCO switch.
what is the voltage like on pin 86 (Red-Blue) on the relay as this is also the common feed to the FCO switch?
#58 jayworth2
jayworth2
  • 73 posts
Posted 03 June 2018 - 10:59 AM
On pin 86 of the fuel pump relay with the multimeter grounded to the engine block i get 12V
#59 siztenboots
Posted 03 June 2018 - 11:18 AM
also  , lift off the black plastic loom cover by the fuel rail
check the red-blue wire on any of the injector plugs for 12v , as this is also common to the fuel pump supply , and this is the output of that relay.
#60 jayworth2
jayworth2
  • 73 posts
Posted 03 June 2018 - 12:52 PM
No 12V at the injectors from the red / blue wire. Found the white / violet connection at the blue plug at the loom of doom & if this is +12V i'am not getting any voltage at it. Checked fuel cut off switch which is closed circuit as it should be & goes open circuit with a bang on it. Really stuck now as to what to check next?
