Loudi V8
#141
Posted 15 January 2019 - 04:24 PM
#142
Posted 18 January 2019 - 12:01 PM
#143
Posted 22 January 2019 - 06:53 AM
Thanks guys. I try to learn stuff I don't know
Ed's definition sounds logical.
Asked a couple of US guys some time back what the difference was between a couch and a sofa. They had no idea
#144
Posted 16 March 2019 - 10:49 AM
decided to go with this gearbox from the v6 TDI I've chosen this as its a cheap derivative and plenty of them about as to whether it can withstand the torque is another matter but being as its supposed to be the same as an 01e box in dimensions and the same as the later Porsche boxes it wont be a problem swapping it out at a later date
done some calculations based on the horsepower and fluid flow dynamics of the Exige v6 body to give an estimated top speed with the ratios in the box
I know they may be a bit wide for a track car but should be interesting for a lazy road car for now.
#145
Posted 16 March 2019 - 04:41 PM
Better build strong bodywork if you are going up to 223 MPH!
#146
Posted 16 March 2019 - 05:56 PM
expect a few other things would come flying off long before the bodywork does lol
#147
Posted 18 March 2019 - 08:54 PM
for those that asked previously with this engine and gearbox, the length from the front of the engine to the centerline of the axle will be 680mm adding a little to the front of the engine to make space for the waterpump
#148
Posted 19 March 2019 - 12:01 AM
#149
Posted 19 March 2019 - 07:13 AM
I went for the longer box as it's very similar to the Porsche box also my engine didn't come with a flywheel so I plan on using the rs4 b7 flywheel lightened and a paddle clutch
#150
Posted 16 January 2020 - 10:35 PM
its been a while since i last posted as work has been in the way alot last year, i managed to start looking at the engine
and decided to junk the direct injection ,i know its a very trick injection system and it saves on fuel giving more power and so on but,after opening up the inlets and looking into the back of the inlet valves i was shocked to find them completely cacked in carbon gunk
,i know its a known problem with direct injection engines but i wasnt expecting to see so much on a 30k engine these audi engines must be dropping efficiency like being pushed off a cliff
with the amount of gunk literaly throtling the inlets it looked like there is atleast 4mm build up on the back of the valves and the surrounding walls so thats why i decided to junk the direct inj and go for port injection to keep the inlets clean with the shower injectors also the engine comes with a AC compressor ive been toying with a single turbo of the g35 or Electric type and using the AC compressor as a chiller intercooler theres a lot of work needed yet but atleast the rest of the engine is in very good condition judging by the cams
the front of the car is going to get a complete aproach regarding the improvement to aerodynamics as far as i can
ive been studying the latest developments regarding the lemans hyperclass and want to get the frontal air distribution as close as i can to those cars
