Vx220 Specialist - Fault Finding
60 replies to this topic
#21 Johnboyhgt
Johnboyhgt
  • 1,313 posts
Posted 16 September 2019 - 12:00 PM
If your really struggling Chris and myself could double up on this, car would need to come to yorkshire though.
Just an option.
#22 Exmantaa
Posted 16 September 2019 - 12:17 PM
Battery = 12.4v - Yep
big X1 plug = 12.4v (goes to starter relay and feed of the K18 relay) - yep
X2 pin 5 (green) measured only 9v (comes from fusebox 7) Ecu shows this 9volt in the logs. Drops to 7volt on starting... - yep
Check voltages on the fuse box in the front (Both sides of each fuse! After you confirmed the direct battery voltage):
Fuse #2,5,6,7,20 & 22 all switched on by Ignition key.
Fuse #8,9,10,11,12,13,14,15 allways on.
X2 pin 1 unknown; should be 12.4v when K18 is activated. (ground pin X2-12; green/pink wire) - I'll go out check this today
X3 pin 13 unknown (should be always >12v from fusebox 8. Ecu back-up feed) - I'll go out check this today
#23 Rosssco
Rosssco
  • 4,185 posts
Posted 16 September 2019 - 12:25 PM
Checked again:
Battery = 12.4v - Same
big X1 plug = 12.4v (goes to starter relay and feed of the K18 relay) - Same
X2 pin 5 (green) measured only 9v (comes from fusebox 7) Ecu shows this 9volt in the logs. Drops to 7volt on starting... Checked today with engine cold - 12.0v
X2 pin 1 unknown; should be 12.4v when K18 is activated. (ground pin X2-12; green/pink wire) - Can't seem to get any reading on this, ignition on or off..
X3 pin 13 unknown (should be always >12v from fusebox 8. Ecu back-up feed) - Can't seem to get any reading on this, ignition on or off..
Fuse 7 - varies between 11.8v and 12.2v
#24 Exmantaa
Posted 16 September 2019 - 01:00 PM
X2 pin 5 (green) measured only 9v (comes from fusebox 7) Ecu shows this 9volt in the logs. Drops to 7volt on starting... Checked today with engine cold - 12.0v  Bit low. should be same as battery voltage  with no load on it, but fuse #7 also measures weird
(Ignition on does not matter for this test. Measure voltages on disconnected X connectors; Car side.)
Measure on X2 pin 1; should be 0 volt
connect X2 pin12 green/pink wire to a ground => Switches the K18 relay. You should hear it clicking.
Measure on X2 pin 1; should be same as battery voltage.
Fuse 7 - varies between 11.8v and 12.2v => should be a very steady battery voltage! What does the voltage do with f.i the lights on?
What measures fuse #8? (always on power)
#25 Rosssco
Rosssco
  • 4,185 posts
Posted 16 September 2019 - 01:45 PM
I measured the voltages at the following fuse locations (with both ign on and off for both):
2 - 10.7v
5 - 0v
6 - 11.84v
7 - 12.06v
20 - not used
22 - 0v
8 - 12.34v
9 - 0v
10 - 0v
11 - 0v
12 - 11.9v
13 - not used
14 - 0v
15 - creep slowly from 3v to settle at 9.3v
#26 vocky
Posted 16 September 2019 - 04:29 PM
correct - it should have 12v when relay K18 is active or when X2-12 is grounded, the K18 supply power is also a permanent 12v which comes from the big fuse FL4 under the windscreen
correct - it should have a permanent 12v from fuse 8
#27 vocky
Posted 16 September 2019 - 04:33 PM
2 - 10.7v
5 - 0v
6 - 11.84v
7 - 12.06v
20 - not used
22 - 0v
8 - 12.34v
9 - 0v
10 - 0v
11 - 0v
12 - 11.9v
13 - not used
14 - 0v
they should all be around 12v, give or take 0.5v. Certainly not - 10.7v / 3v / 9.3v
Fuse 5 and Fuse 22 are ignition switched 12v
Fuses 9,10,11,14 should all be a permanent 12v
#28 vocky
Posted 16 September 2019 - 04:34 PM
I suspect you have some wiring corrosion around the front fuse box
#29 Rosssco
Rosssco
  • 4,185 posts
Posted 16 September 2019 - 05:34 PM
Doesn't sound good tbh does it  :huh:
Thing is, car will start 'normally' if left for a while. Only repeated starts fail..
#30 vocky
Posted 16 September 2019 - 05:44 PM
two options;
1 - bodge it and wait for it to return :P
2 - replace the loom and stop worrying about it :D
#31 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 16 September 2019 - 07:33 PM
Back on Track use a brilliant auto electrician, Toby
He's not the fella they use now, sadly.
#32 Exmantaa
Posted 16 September 2019 - 10:28 PM
2 - 10.7v
5 - 0v      => reverse & stop lights not working?
6 - 11.84v
7 - 12.06v
20 - not used
22 - 0v  => ABS...
8 - 12.34v
9 - 0v    => Hazard Warning lights not working?
10 - 0v  => Horn not working?
11 - 0v  => interior light + alarm system not working?
12 - 11.9v  => cooling fan turning slow?
13 - not used
19
14 - 0v   => front lights not working??
15 - creep slowly from 3v to settle at 9.3v  => Radio  Weird behavior...
Some real dodgy wiring there up front and probably a lot worse when you try to pull some Amps through it... :unsure:
#33 Rosssco
Rosssco
  • 4,185 posts
Posted 17 September 2019 - 10:20 AM
Yeah, who knows! I'm gonna buy the complete loom anyway to fit, although I'll try inspect the front wiring again.
At least then I can say I've effectively replaced every major electrical component on the car:
  • Alternator
  • Starter
  • Coil pack
  • Injectors
  • Throttle body
  • ECU
  • Crank sensor
  • T-Map sensor
  • Brown and Grey relays
  • Relay holders
  • Engine loom
  • Battery
  • Earth cables
  • Battery Live terminal
  • Heater unit (discovered a leak)
:huh:  :D
Edited by Rosssco, 17 September 2019 - 10:21 AM.
#34 smiley
Posted 17 September 2019 - 01:59 PM
wow, that Is one fecking expensive starting problem :huh:
#35 Rosssco
Rosssco
  • 4,185 posts
Posted 17 September 2019 - 02:13 PM
Yep. I'm up to about £850 on parts alone, and coming up for a year out of action, and its still fooked! Plus the body is even tattier because its just been sitting, discs rusted up etc.
Never had a car quite this unreliable, but that's part of the joy, right? :lol:
#36 R30SS
R30SS
  • 25 posts
Posted 17 September 2019 - 03:26 PM
Hi mate. I use Automek in East Kilbride - worth adding to the list.
Their main man Andrew had a racing Elise and has done plenty K series swaps, as well as maintaining a number of customer VX's so he knows every nut and bolt on these. Give him a bell
#37 Rosssco
Rosssco
  • 4,185 posts
Posted 17 September 2019 - 07:13 PM
Cheers Ross. I forgot about Automek and that they had Elise / VX knowledge..
The car might end up going down the road for some bodywork too, so Automek could be a good shout if it comes to it.
#38 Matthew Bentley Racing Ltd
  • 774 posts
Posted 18 September 2019 - 08:45 AM
We are happy to try and help, not sure how far you are from us
MBR
#39 Ivor
Ivor
  • 2,219 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 19 September 2019 - 09:52 PM
When if does start does it run ok without issue until you turn it off?
#40 Rosssco
Rosssco
  • 4,185 posts
Posted 21 September 2019 - 12:08 PM
Yeah, it seems to run ok initially, but after two or three starts it just goes down hill till it won't even turn over.
