Vx220 Specialist - Fault Finding
Posted 15 September 2019 - 03:44 PM
Anyone know of a decent VX220 specialist in the UK who can deal with electrical fault finding?
Need someone with in-depth knowledge of the car. Distance isn’t too much of an issue as the car will need to be shipped there anyway.
Cheers,
Ross
Posted 15 September 2019 - 03:53 PM
what kind of issue? as in.. what's it doing... or not doing.
Edited by chris_uk, 15 September 2019 - 03:53 PM.
Posted 15 September 2019 - 04:18 PM
Massive saga and too long to go into Chris (think I’ve started about 3 threads on it haha), but the skinny is it won’t start (does occasionally) then won’t. Replaced most engine bay components etc.
Posted 15 September 2019 - 04:33 PM
Posted 15 September 2019 - 04:52 PM
Back on Track use a brilliant auto electrician, Toby
Thanks for that. Other end of the country, but will add to the list..
Posted 15 September 2019 - 05:35 PM
He has a few issues;
Main problem is/was the buzzing noise, but he has/had a wrong MAP and IAT signal and on top of that a too low engine system voltage. (~7volt measured at the ecu...)
Edited by Exmantaa, 15 September 2019 - 05:36 PM.
Posted 15 September 2019 - 05:39 PM
Posted 15 September 2019 - 07:07 PM
Posted 15 September 2019 - 07:10 PM
Vocky is selling a complete new chassis loom - nuclear option! But surely that would solve it...
Posted 15 September 2019 - 07:13 PM
Hi mate I’m a new member but have had VX from the beginning of time. Had most problems reported on this site and a few others. My VX suddenly refused to start I tried lots of things, no luck, called out RAC they replaced stuff no luck. They left to discuss it with tech guys. I then disconnect battery and refitted, it started. Fixed ? No it did it again a few days later, disconnected battery again, started. So I cleaned all the main battery and other wire connections. That did it. Assume management system loosing power in a way that messed it up. Long shot but you must be pulling your hair out I was.
Thanks mate! Yeah, I've tried everything I can think of, plus lots of help / pointers from experienced members here, but I have to realise my own limitations. Replaced the battery terminals and all earth wires etc.
Been off the road for nearly a year now because of it.
Did you ever try another ecu?
Yeah, but no difference as suspected.
Posted 15 September 2019 - 09:32 PM
Shitty earths or damage to the wire between the fuse box an the ECU. Had one break down within the insulation.
If your getting 7v at the ECU but 12v at the battery end. Obvious place to start.
Posted 16 September 2019 - 07:48 AM
He measured >12volt at the battery terminals and only 7-9volt at the X2 connector pin(s), so something is probably dodgy at the fusebox side. Car just needs some methodical fault finding...
(And replacing the entire car loom in a VX is not an easy task... )
Posted 16 September 2019 - 08:13 AM
have you put in a jump wire (from the battery to the plug) to rule out the wiring from battery to plug?
Posted 16 September 2019 - 08:48 AM
So we're talking the wiring that goes into the chassis, through to the fuse box at the front end wheel arch?
I can have a look at the fuse box for dodgy connectors or split wires going in.
Earths have all been replaced (including cables and terminals), also ran a jump lead direct from the battery to the engine, and no difference.
Posted 16 September 2019 - 08:50 AM
Which plug do you mean Chris?
Oh and if you mean the X1 plug (big 4-pin plug), I checked that and it was recieving battery voltage (12.4v ish)
Edited by Rosssco, 16 September 2019 - 09:03 AM.
Posted 16 September 2019 - 09:33 AM
ECU, wrong key, no fuel, blockage fuel line. Water in fuel, no fuel pressure. Don’t get stuck just on electrics. All you can do is tick them off one at a time. Good luck hope you sort it soon.
Posted 16 September 2019 - 09:34 AM
From memory he has checked;
Battery = 12.4v
big X1 plug = 12.4v (goes to starter relay and feed of the K18 relay)
X2 pin 5 (green) measured only 9v (comes from fusebox 7) Ecu shows this 9volt in the logs. Drops to 7volt on starting...
X2 pin 1 unknown; should be 12.4v when K18 is activated. (ground pin X2-12; green/pink wire)
X3 pin 13 unknown (should be always >12v from fusebox 8. Ecu back-up feed)
Edited by Exmantaa, 16 September 2019 - 09:36 AM.
Posted 16 September 2019 - 09:58 AM
Yeah, tried all of those. Car will start ok if left disconnected from the battery for a while. Further starts are the issue.
So its a wiring / earthing / voltage issue related to the engine control / sensors.
Posted 16 September 2019 - 10:00 AM
Battery = 12.4v
Battery = 12.4v - Yep
big X1 plug = 12.4v (goes to starter relay and feed of the K18 relay) - yep
X2 pin 5 (green) measured only 9v (comes from fusebox 7) Ecu shows this 9volt in the logs. Drops to 7volt on starting... - yep
X2 pin 1 unknown; should be 12.4v when K18 is activated. (ground pin X2-12; green/pink wire) - I'll go out check this today
X3 pin 13 unknown (should be always >12v from fusebox 8. Ecu back-up feed) - I'll go out check this today
