Any Interest In Alloy Uprights?
71 replies to this topic
#1 Tonie Pettersson
Tonie Pettersson
  • 423 posts
Posted 21 November 2019 - 08:11 AM
I might have a go at making a few more custom alloy uprights if there is any interest.
There are two versions I can make
Version 1
  • 17.5mm raised centre
  • Allowing more camber
  • Weights 1600g total per side
  • Aluminium 7075-T651
  • Hard anodized
  • Helicoil on all threads
  • 7000:- SEK plus shipping (usually 4-500:- SEK)
Version 2
  • 30mm raised centre
  • Weights 2000g total per side
  • Allowing 4-pot fitment
  • Hard anodized
  • 5500:- SEK plus shipping (usually 4-500:- SEK)
If there is interest and everything goes as planned they should be available for delivery in February-March. It comes down to how much work load the guys at the surface treatment has at the moment.
Version 1 pictures
Version 2 pictures
#2 FLD
Posted 21 November 2019 - 08:32 AM
Any rears in progress :poke:
#3 Tonie Pettersson
Tonie Pettersson
  • 423 posts
Posted 21 November 2019 - 10:05 AM
Me lazy... :blush:
#4 FLD
Posted 21 November 2019 - 10:09 AM
I wouldn't say that. Don't you have two young children? I have a 5 month old and she eats my time!
Edited by FLD, 21 November 2019 - 10:09 AM.
#5 Rosssco
Rosssco
  • 4,185 posts
Posted 21 November 2019 - 10:15 AM
Being ignorant, do these provide any benefit to the suspension operation in a 'road' car running normal-ish ride height. Weight saving aside.
Understand the benefits in a car running significantly lower than standard.
#6 sford
sford
  • 1,459 posts
Posted 21 November 2019 - 10:52 AM
I'd be interested once christmas dies down. 7500SEK is roughly £600 I think.
#7 FLD
Posted 21 November 2019 - 11:17 AM
These were one of the best things I put on my car. My car is not excessively low (120/130 I think) but I found the steering a bit 'snatchy' over the bumps. (Sorry, I'm no expert so can't describe it any technically accurate way). With these uprights the 'feel' of the steering was massively improved. There's a lot less fighting going on.
#8 sford
sford
  • 1,459 posts
Posted 21 November 2019 - 11:22 AM
What suspension are you running and other associated bits? I'd be looking at the version 1 uprights as have no desire to run 4 pots.
#9 Rosssco
Rosssco
  • 4,185 posts
Posted 21 November 2019 - 11:30 AM
Sounds like they have the effect of reducing bumpsteer from what you're saying, which is what I thoughts they helped with.
#10 FLD
Posted 21 November 2019 - 11:42 AM
Std wishbones with polybushes, 1" eliseparts ARB, nitron multiways (cant remember spring rates I'm afraid), 16/17 TD's, std rack
If I've missed anything let me know
#11 Tonie Pettersson
Tonie Pettersson
  • 423 posts
Posted 21 November 2019 - 11:59 AM
Well the boys are four and eight now so switched focus from shitty diapers and no sleep to running around on activities like hockey, football and biking instead. All good stuff :D.
Grats on the little one!
For a car running mainly on road with oem ride height, not really. It´s more when the car is lowered and you get bump steer problems.
Nice, I´ll add you to the list. Seems correct with £600.
You can use the standard caliper on version 2 as well.
#12 2-20
2-20
  • 1,317 posts
Posted 21 November 2019 - 04:58 PM
Why this high price difference between the 2 versions ? I was thinking version 1 but with this 1500 SEK difference and the fact that you can still use a standard caliper, i have to think twice about it...
#13 sford
sford
  • 1,459 posts
Posted 21 November 2019 - 05:12 PM
I'm thinking this. I run standard calipers and not planning on upgrading. I run standard size discs and don't plan on going up a size. Ride height is probably the biggest issue as I run my car fairly low on NSS2.
#14 Tonie Pettersson
Tonie Pettersson
  • 423 posts
Posted 21 November 2019 - 08:25 PM
It all comes down to how time consuming they are to manufacture.
Version 1 takes roughly 2.5-3 times longer in the cnc-machine, there are more tools to set up, a longer first part run in and so on compared to version 2.
Edited by Tonie Pettersson, 21 November 2019 - 08:28 PM.
#15 Nev
Posted 21 November 2019 - 08:43 PM
I'd also be interested in a rear set... :)
#16 NOSBandit
NOSBandit
  • 271 posts
Posted 21 November 2019 - 10:04 PM
I'd be interested in a version 2 for the front and a set of rears.
Sent from my SM-G935F using Tapatalk
#17 Jetdotter
Jetdotter
  • 60 posts
  • Interests:Supermotos
    Family
    Moto gp
Posted 21 November 2019 - 10:11 PM
Interested in version 2 and rears
#18 2-20
2-20
  • 1,317 posts
Posted 21 November 2019 - 10:55 PM
Anyone knows the weight of the OEM front uprights ??
#19 nicollow
nicollow
  • 3,801 posts
Posted 21 November 2019 - 11:03 PM
Sooooo tempted by Version 1 uprights... Need to check the back of the sofa to get the money together tho!
#20 Tonie Pettersson
Tonie Pettersson
  • 423 posts
Posted 22 November 2019 - 07:00 AM
Just to clarify, there are no rears available at the moment. But nice to see there´s interest :).
I should have the numbers somewhere but can´t seem to locate it now. Think I have an OEM upright in the garage, gonna check when I get home from work.
