That should run the fuel pump. Again jam jar under to check flow. Only needs to be on a second or two to check.
Posted 12 April 2020 - 10:57 AM
Posted 12 April 2020 - 11:28 AM
Righto, that shall be the next thing I do then. I shall get back to you all as soon as I have tried this, thank you again guys.Very likely. So that makes it a bit easier. As said before bridge the relay. There's 3 relays in the boot. Yellow, brown, grey. Grey one does the fuel pump. Take a piece of wire and connect the brown/grey to the thick purple/white as in the picture.
Posted 12 April 2020 - 01:51 PM
Seems to be an echo round here.
Posted 12 April 2020 - 01:54 PM
Posted 12 April 2020 - 02:36 PM
I did acknowledge what you said zoobeef, thank as well aha
Posted 12 April 2020 - 04:58 PM
Hi my first bit of info since becoming a member. I had same problem. After 4 hours, Called RAC, they did lots of things said I had wrong key, did I have another, I did so used that nothing. Then I remembered the fitter in the garage I had it from, said if the battery is taken off be careful when you put it back on, sort of ready stead go. Took battery off reconnected and boom. Started first time. Worth a try. Good luck.
Posted 12 April 2020 - 05:02 PM
Posted 12 April 2020 - 05:25 PM
Sorry I’m referring to the main car battery. If it’s not put on correctly the key is not recognised, haven a clue why but the error code was key fault.
Posted 03 April 2021 - 05:45 AM
