I've just
finally fitted by spraybar, tubing and connectors - what a massive difference actually having water on your windscreen when it's wiping actually makes!!! Great mod! I've gone the whole hog and kept the washer jets working as well as the spray bar.
From the related threads on SELOC, I hear that >
Elise-Shop< are putting a kit together based around the citroen spray bar for less than €20. I can't help feeling that the pug 405 spray bar is the better option though...
The toughest decision was where to make the whole through the gutter!
I still need to route the pipes better by the washer bottle and I think a non-return valve would be a good move, maybe even some sort of adjustable valve that I could adjust the pressure bias between the jets and the spraybar.
Here's a pic of the elbow bulkhead with push-fittings I used to pass through the gutter at the base of the windscreen. I used rubber washers each side to make sure that water can't seep through from the gutter.
