Windscreen Washer Modification
75 replies to this topic
#61 Ratspants
Ratspants
  • 2,739 posts
Posted 26 April 2006 - 04:35 PM
Does anyone have the part number for the 405 spray bar?
Although the Citroen part is good, the top loopy bit seems very tricky to set up so that the water doesn't just hit the wiper arm and go no-where.
Also, there's a window washer kit (using the Citreon part) available from >elise-shop.com<. But it's still cheaper to get the pipe from B&Q and get the spray bar from the French manufacturer of your choice.
Cheers,
Ben
#62 Ratspants
Ratspants
  • 2,739 posts
Posted 26 April 2006 - 04:45 PM
Peugeot part number 643861 (Bin A6C5), "SPRAYING RAMP*P4WT" £5.46 +VAT
this info was for 2004 though!
How handy.
Ben
Edited by Ratspants, 26 April 2006 - 04:46 PM.
#63 Winstar
Winstar
  • 4,264 posts
Posted 20 December 2006 - 08:19 PM
Having just filled up my water bottle, for the first time since i cant remember, I thought I'd resurrect this thread for the benifit of all the new people on the site. I still maintain this is the best mod i've done and will pay for it's self in washer fluid in a couple of weeks at this time of year with all the grit on the roads.
#64 Ratspants
Ratspants
  • 2,739 posts
Posted 21 December 2006 - 09:11 AM
Having just filled up my water bottle, for the first time since i cant remember, I thought I'd resurrect this thread for the benefit of all the new people on the site.
This and changing the relay for less wipes after a spray (as well as variable intermittent)
I'm still using the Citroën spray bar and it's fine.
Ben
#65 JawZ
JawZ
  • 2,571 posts
Posted 21 December 2006 - 10:08 AM
Reminds me of the fact that I have never needed to refill my washerbottle yet :D
Have had the car since 2004 so I guess our roads are pretty clean :P
I don't have this mod btw :drink:
#66 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 21 December 2006 - 11:19 AM
thumbsup Top resurrection if ever I've seen one. I'm off to Peugeot now...
#67 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 21 December 2006 - 11:23 AM
Could be worth looking at the Honda CRV washer as it's spray jet has a wide Arc of about 60 degree. maybe able to be moded to fit the car
#68 Muncher
Muncher
  • 4,494 posts
Posted 21 December 2006 - 12:19 PM
Nick, I think it's just the design of the car that would make another jet type solution like that tricky. The angle is so acute and the washer jets are mounted on little stalks, nothing like I've seen on any other car. Very happy with mine still :)
#69 NickH
NickH
  • 2,171 posts
Posted 11 April 2007 - 03:43 PM
Thought this would be a useful bump with all the roofless driving going on at the moment rallly Did mine last year and can honestly say it's one of the most practical mods I've done thumbsup Nick
#70 Ratspants
Ratspants
  • 2,739 posts
Posted 11 April 2007 - 05:38 PM
thumbsup I was thinking just last week how good the spray bar and relay mods are together!
Ben
#71 njc11
njc11
  • 1,057 posts
Posted 13 April 2007 - 02:00 PM
Just fitted my spray bar..
What a massive difference! 7 little holes in the bar actually fire on to the windscreen with amazing force! thumbsup
Excellent mod.. like what was said above.. doing this mod with the wiper relay has to be one of the most effective mods thumbsup
The only problem i had was the washer bottle! It had old liquid in it and kept getting blocked so had to thoroughly rince the bottleout and remove the rubber bung that the motor sits in as all the gunk was round that..
As for the pipes.. i used everything that was supplied with the arm except one clip, i went to b&q and got the 3mm & 5mm pipe and also some hose couplers (Eliza Tinsley pack with a selection of different angles etc) pushed one end into the black pipe on the spray bar then the other end into the 3mm clear pipe (soaked in hot water first) then put 3mm pipe inside the 5mm pipe, then the 5mm pipe straight onto the motor! Job done and works spot on..
Hopefully on this years Euro road trip i will be able to remove flys with ease! thumbsup :lol:
To anyone who hasnt doen this...DO IT!!
Cheers
Nick
chinky chinky
#72 Winstar
Winstar
  • 4,264 posts
Posted 18 December 2007 - 09:26 PM
It's the time of year again so I thought I bump it again for the new members
#73 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 20 December 2007 - 05:14 PM
I said it then, and I'll say it now almost 1 year on. Top resurrection thumbsup
#74 Winstar
Winstar
  • 4,264 posts
Posted 30 July 2008 - 03:21 PM
After using about half a bottle of washer fluid clearing the winscreen my new VX, I went home and swaped this set up off my NA. Once again I can't belive how much better it is than std so I though I'd give the thread a bump
#75 luna_s
luna_s
  • 1,934 posts
Posted 30 July 2008 - 03:23 PM
i used the spray bar mod - worked great, but now i'm a big fan of the valeo vm15 wiper blade with inbuilt washer system
#76 Jase_MK
Jase_MK
  • 6,277 posts
Posted 30 July 2008 - 03:45 PM
My std nozzles are crap. I'm guessing though, as I have a Bosch Aero blade from a Passat instead of the normal wiper arm, this probably won't fit? Maybe I'll try and fab something up DIY stylee
