Windscreen Washer Modification
#21
Posted 10 January 2006 - 11:12 PM
#22
Posted 10 January 2006 - 11:35 PM
Mine have turned into a trickle recently and don't make it past half way up the screenAre you lot having problems with the standard washer jets? or is this just a cool mod?
Because of course it's cool to put as many French parts on your VX as possible too
#23
Posted 11 January 2006 - 08:33 AM
Oh yeh forgot about that!I have a spare if anyone would like one.
Err, yes please.
(Save one for the bimmer too TAGL)
#24
Posted 11 January 2006 - 08:54 AM
it's and art to get the windscreen cleaned now as it is..Are you lot having problems with the standard washer jets? or is this just a cool mod?
#25
Posted 11 January 2006 - 09:07 AM
Mine is amply powerful but just seems to bounce of the windscreen. I was following another VX once, he washed his windows and you could see the streams of water just bouncing off the windscreen and into the air. Having a system like this would distribute the water MUCH better. The Elise guys seem to think it is a vast improvement.Mine have turned into a trickle recently and don't make it past half way up the screenAre you lot having problems with the standard washer jets? or is this just a cool mod?
I wouldn't bother if it wasn't for such a cheap fix.
Since it's cheap and non-destructive I think I'll give it a whirl (esp. if you guys rate it too)
Ben
Edited by Ratspants, 11 January 2006 - 09:31 AM.
#26
Posted 11 January 2006 - 12:23 PM
#27
Posted 11 January 2006 - 12:56 PM
Edited by NickH, 11 January 2006 - 12:58 PM.
#28
Posted 12 January 2006 - 05:03 PM
#29
Posted 12 January 2006 - 06:19 PM
#31
Posted 12 January 2006 - 06:59 PM
#32
Posted 12 January 2006 - 07:24 PM
Sure.top man - Ill add that to how to guide in the other thread if that is OK.
Dave
#33
Posted 12 January 2006 - 07:46 PM
#34
Posted 13 January 2006 - 05:38 PM
#35
Posted 13 January 2006 - 05:45 PM
It would be a real pain in the arse to do that. You'd need to disconnect both of the jets otherwise you'd get half of the water pressure in the bar. It's really awkward to get to the underside of the jets to get a feed and the jets don't come out easily, it at all. It also wouldn't look as neat doing that.Did you consider connecting the spray bar to one of the existing jet outlets? Is there a reason why this wouldn't work?
My way just requires pulling one tube off the pump so is nice and simple to revert back to the old way should you want to.
#36
Posted 13 January 2006 - 07:34 PM
#37
Posted 14 January 2006 - 12:00 AM
#38
Posted 14 January 2006 - 05:00 PM
#39
Posted 15 January 2006 - 08:21 AM
#40
Posted 15 January 2006 - 12:08 PM
