I've encountered plenty of heat issues from my 2ubular exhaust. I initially wrapped the manifold, which helped a great deal; accept it just transferred the heat further down the exhaust. I melted 2 02 sensors an engine mount, cables & caused problems with my gearbox cables. I even melted the clam & paintwork around the single exhaust tip.
I now have heat shields covering all sensitive areas near to the exhaust. It still amazes me that all the other S/C cars out there have not also suffered the same heat problems...Yes Nick, I am also referring to you!!!
MaxR
Max
I had heat issues with the pipes of the Milltek burning the clam where they exit and also holding excess heat around the silencer itself. They only materialised after i put on the diffuser so i took it off and no issues ever since. I also tried cutting holes in the diffuser (probably reducing it's dynamic effect) and the only thing that worked for me was removing it and putting the std part back on.
I'll be trying out a 2.5" manifold & system in the next 2 - 3 weeks so will see how that changes things. The heatshield between the manifold & boot is also knackered so will be replacing it as well. Did you guys use the 3, 2 or single layer nimbus material.
Edited by PaulCP, 06 May 2009 - 09:20 AM.
