In essence, it will be like bolting Exige stuff on?
It WILL be the same as they are the same IIRC.
Posted 10 July 2008 - 12:10 PM
Posted 10 July 2008 - 02:56 PM
Posted 10 July 2008 - 03:06 PM
Posted 10 July 2008 - 03:12 PM
Posted 10 July 2008 - 03:13 PM
Edited by LazyDonkey, 10 July 2008 - 03:14 PM.
Posted 10 July 2008 - 03:15 PM
CAn't believe you were typing for ages and that was the outcome
The question is, will you want 16"s after the exige set up
Posted 10 July 2008 - 07:44 PM
You can lower the front suspension easily by mounting the Elise/Exige shock bracket set from Elise-shop.
The front ones will fit the VX and lowers the front approx. 15mm. Only worry is that you have to fab a mounting bracket for the ABS unit. Easy...
If this is not low enough, you can always modify the dampers by adding an extra groove for the circlip. As this holds the upper spring platform in place, make it sit higher will lower your ride height. (Or modify them with a thread kit to get an adjustable system...) Will look for some pics.
Edited by Exmantaa, 10 July 2008 - 08:13 PM.
Posted 10 July 2008 - 08:08 PM
Edited by Exmantaa, 10 July 2008 - 08:17 PM.
Posted 10 July 2008 - 08:14 PM
Posted 10 July 2008 - 08:29 PM
Posted 10 July 2008 - 08:36 PM
Posted 10 July 2008 - 11:02 PM
As a halfway option there is also the new Nitron Racing Reds - although I'm not sure if the S2 Yota engined elise ones are on sale yet.
Posted 12 July 2008 - 11:49 AM
Posted 12 July 2008 - 12:20 PM
Once the VXR stuff is on I'll look at the wheels again. It seems to be a major can of worms what size front to go for but I do know I like the aesthetics of black TD's on a silver car ... that's a start!
Posted 13 July 2008 - 08:55 PM
Posted 13 July 2008 - 09:41 PM
They look fantastic except that they are heavier than TD's - that was my deciding factor.
Posted 14 July 2008 - 07:23 AM
Posted 14 July 2008 - 02:35 PM
Made meI'm just going to eat less pies, lose half a stone ...
Posted 14 July 2008 - 07:22 PM
but it was the unsprung weight I was thinking of and that's why I didn't worry about the jam doughnut I just scoffed
Posted 15 July 2008 - 08:54 AM
