Lsj Engine
#21
Posted 07 August 2009 - 10:44 AM
#22
Posted 07 August 2009 - 11:20 AM
you need to use the lsj flywheel, but otherwise it's quite an easy swap.
Luckily I do have the lsj flywheel.
I will first have to prepare the engine with GM's suggestions with higher flow fuel injectors, forged pistons (I think I'll go for 10:1 CR) valve springs, ported Cylinder head ( will take me some time, last time I did one is more than 10 years ago... aie) and more agressive cams (undecided)
I may be looking at more than a year for this project....
#24
Posted 07 August 2009 - 12:48 PM
I somewhere read that the LSJ has the same 8 bolt pattern as the XE/LET engines? Not sure though. Have to check if my old XE flywheel fits the LSJ crank...
How much power do you intend to run? The standard LSJ pistons seem to do fine in the US till ~300 Supercharged Wheel HP. (And in that GM build book they swap to 10:0 because they also used hotter cams, which lower your dynamic compression a bit.)
That article is pre-Harrop TVS, so things have evolved a bit now.
Work on the LSJ head, valve springs & cams (have a set GMR SC-cams) are also on my to-do list. And that Harrop is soooooo tempting...
A year is long, so do it in stages and SC your 2,2 first with the Courtenay remap. Will not cost you that much and you can taste some SC-power.
#25
Posted 07 August 2009 - 01:38 PM
#26
Posted 07 August 2009 - 02:11 PM
Bwa, these need solid lifters, they are crap
#27
Posted 07 August 2009 - 02:26 PM
That article is pre-Harrop TVS, so things have evolved a bit now.![]()
I should be satisfied with 300hp max and not rely on too much boost to generate power. I would like for the transmission and chassis to be just as reliable as the engine so I will not go over 300hp. My breaks will also have to be changed to stop all that power.
Than hit the track and learn how to drive all over again.
I tought about putting the supercharger on the std engine but I'm afraid that I will postpone and postpone my initial project as I'm sure I will love the supercharger power.
(I better not tell my wife, she'll prefer that option
#28
Posted 07 August 2009 - 04:17 PM
Bwa, these need solid lifters, they are crap![]()
Yes, I know...
That's why they're still in the box.. .
#29
Posted 07 August 2009 - 04:27 PM
Why are they crap?
#30
Posted 07 August 2009 - 05:48 PM
#31
Posted 07 August 2009 - 05:50 PM
Why are they crap?
Smaller base circle, what the hydro lash adjusters don't like.
(Anybody can PM me a low cost solution for this? Shims underneath the lifters does not seem to work well with the LSJ's head design. (You loose the shims according some US guys...) Not sure if valve stem caps will work on our lifters?)
#32
Posted 07 August 2009 - 07:24 PM
#33
Posted 07 August 2009 - 07:42 PM
#34
Posted 07 August 2009 - 08:11 PM
#35
Posted 07 August 2009 - 08:36 PM
What I can't understand is...
if it is only a smaller base circle stuff, then it will work with new hydro lifters
it is exactly the same issue than with piper regrinds where you get noises if you don't change them
or maybe the base circle is so much smaller than it is out of the range for the hydro lifters ?
Going way off topic and opening the GM box... =>
GMR Lobe top-bottom = 34.61mm
GMR Base circle diam. = 27.96mm, giving a 6.65mm cam lift.
Could not find stock base circle data so quickly.
#36
Posted 07 August 2009 - 08:52 PM
#37
Posted 08 August 2009 - 12:33 PM
#38
Posted 08 August 2009 - 12:43 PM
#39
Posted 08 August 2009 - 01:31 PM
#40
Posted 08 August 2009 - 03:46 PM
