I think, from what I understand, is that the oil from the filter can kill the AMM - so in theory a dry filter element (eg paper or foam) would not cause any problemshow do you figure that out? mine has run perfectly fine like this for months. the only difference is that it will probably be sending a bit more air through the AMM, can't see how that will kill it really.
I can only assume that an over oiled filter would cause problems...
cheers, i suppose that could make sense, if the filter was blathered in oil. mine is oiled and have experienced no problems yet, will see how it goes.........
this is going a little off topic, but have a search. It has been covered many times before. People have used many types of air filters on VXT's, all have sooner or later had there AMM's blow. There is the option of upgrading to the VXR astra/vectra 80mm AMM but can be a bit expensive, this is apparently a bit more robust then the standard VXT AMM.
