Abs Upgrade
82 replies to this topic
#1 C43
C43
  • 108 posts
  • Interests:Lotus Europa.
Posted 17 January 2010 - 07:56 PM
Hi I am thinking of upgrading my Europa to the Exige ABS unit as my current unit is setup for 17" fronts and I am now running 16" fronts. I know on the VX you guys change the ABS unit to the Exige one as it is 4 channel. Is there any particual trick to changing the ABS unit and anyone have a good source of cheap units? cheers C43
#2 chris_uk
Posted 17 January 2010 - 08:03 PM
ive disconnected my abs on 16's with 888's
#3 C43
C43
  • 108 posts
Posted 17 January 2010 - 08:50 PM
I have done the same. This is fine for track days in the dry but for wet running on the road I would rather have ABS. Must be getting old...
#4 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 17 January 2010 - 09:14 PM
Speak to MartinS he upgraded to the VXR/Exige setup. He's happy with it too thumbsup
#5 Steve B
Steve B
  • 964 posts
  • Interests:Mountain Biking and Cars
Posted 17 January 2010 - 09:15 PM
Hi
cheers
C43
Every time I see a post like this I add :-
"If anyone wants to do a group buy and knows a good source of Exige ABS modules I'll definately want one".
chinky chinky
#6 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 18 January 2010 - 08:15 AM
chinky chinky
:yeahthat:
#7 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 18 January 2010 - 11:45 AM
I fitted the vxr one to mine and it was a big improvement. Its fits in seconds but you have to get a Lotus dealer of specialist with a Lotus tech 2 to get rid of the warning light, as its too deep in the system for a normal tech 2. I still turn it off on track, but its always on on the road now, and after 6000 miles have had no scares, whereas the original nearly killed me a few times and I had to turn it off. Martin s
#8 Steffe
Steffe
  • 231 posts
Posted 18 January 2010 - 12:15 PM
Whats the main difference between the VX and VXR ABS unit? How much did it cost? What is the dangerous bit with the original system? I have only noticed that the ABS seems to step in to early in a strange way, it feels as you cant use the brakes full potential. Best Regards Steffe
#9 alanoo
alanoo
  • 1,324 posts
Posted 18 January 2010 - 12:34 PM
I upgraded to an Exige S ABS ECU, 2 min plug and play swap, no warning light for me. Works great even on track, I now leave it on on track and generally don't even notice it. Brand new units are not that pricey from Lotus, great mod. (I think the last 2-11 and Cup 260 abs software is even better, not sure if this is true or not)
#10 Steve B
Steve B
  • 964 posts
Posted 18 January 2010 - 01:11 PM
Are you in an n/a or turbo, does it matter?
Do you have the part number for the unit? I may just order one if"not that pricey" really isn't that pricey :)
#11 techieboy
Posted 18 January 2010 - 01:44 PM
Circa £500 last time I got a price for one. :(
#12 Steve B
Steve B
  • 964 posts
Posted 18 January 2010 - 01:48 PM
Ah, I count that as expensive.
#13 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 18 January 2010 - 01:56 PM
Have teh VXR / Exige / 11R ABS unit and def a lot better than oe which is well pants lol Still turn mine off in hot weather and on track as you still lose some of the initial bite feel to the brakes, fine with it turned off :) Interesting that the new cup version has been revised, if true? Hurt me paying £250 for mine :(
#14 Steve B
Steve B
  • 964 posts
Posted 18 January 2010 - 03:00 PM
http://www.bell-colv...p?Id=A120J6000F
Very expensive £729.32 (£856.95 inc VAT)
Edited by Steve B, 18 January 2010 - 03:01 PM.
#15 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 18 January 2010 - 03:17 PM
Breakers yard it is :o forgot just how expensive they are :(
#16 alanoo
alanoo
  • 1,324 posts
Posted 18 January 2010 - 04:01 PM
Except the good part number is http://www.bell-colv...p?Id=A120J6004S
Used to be 280£ inc a few months ago....
#17 techieboy
Posted 18 January 2010 - 04:02 PM
They said it was an error when I tried to buy at that original price.
#18 Steve B
Steve B
  • 964 posts
Posted 18 January 2010 - 04:03 PM
So is it the control module or actuator thats needed?
#19 techieboy
Control module/ECU only required. You use the same actuator.
#20 alanoo
alanoo
  • 1,324 posts
Posted 18 January 2010 - 04:39 PM
Most likely you got your quote just during the price update, cause I got it priced at something around 390€ at a french Lotus dealer
The ECU is the actuator (it is not only an ECU computing part), the stuff it actuates is the hydraulic module below it
Edited by alanoo, 18 January 2010 - 04:41 PM.
