They said it was an error when I tried to buy at that original price.Except the good part number is http://www.bell-colv...p?Id=A120J6004S
Used to be 280£ inc a few months ago....
Most likely you got your quote just during the price update, cause I got it priced at something around 390€ at a french Lotus dealer
Control module/ECU only required. You use the same actuator.So is it the control module or actuator thats needed?
The ECU is the actuator (it is not only an ECU computing part), the stuff it actuates is the hydraulic module below it
Ok so the two parts on bell & colvill :-
One that you posted "ECU Kit - ABS Actuator £422.05 (£495.91 inc VAT) Order Code : A120J6004S"
One that I posted "ABS Control Module £729.32 (£856.95 inc VAT) Order Code : A120J6000F"
Everyone has always talked about needing the "Module" rather than an "Actuator", so to get the terminology correct, for the ABS upgrade to Exige S2 4 channel ABS you need the Exige ABS Actuator you don't need the ABS control module?
Edited by Steve B, 18 January 2010 - 06:57 PM.
