Would You Upgrade Current Car To Stage 4 Or.......
#61
Posted 30 August 2010 - 10:18 PM
#62
Posted 30 August 2010 - 11:27 PM
#63
Posted 31 August 2010 - 05:02 PM
#64
Posted 31 August 2010 - 07:42 PM
#65
Posted 01 September 2010 - 07:48 AM
Plenty of food for thought, at the moment im guessing just for stage 4 power i'd be looking at around £4.5k including clutch. Then like some have said there is suspension, wheels & tyres 16/17 combo, brakes and lsd so looking at nearer £8K maybe?
To swap for a stage 4 car i'd be looking at around £2-3k but then there is the hassle of selling mine, waiting for the right car etc so its by no means a no-brainer.
Interesting that someone mentioned there might not be as big a difference between stage 2 and 4 on the road in which case that could be a factor as it's only ever been used for road use so might not be worth doing unless i decide to start doing trackdays.
Stage 4
If your already stage 2, so ur talking an extra 3k for stage 4, plus a clutch, Courtneys Competition' Clutch is £500 with the cylinder, I know Loads of garages that will fit one for about a 5th of the courtney £500 fitting figure (I guess maybe they just dont want to be changing clutches?) Stage 4 is only not drivable round towns if you get the paddle clutch, which we are not talking about.
Brakes
Ive been bullied into telling you: New disks and Mintex 1155 pads from Camskill £200
ATE Superblue Brake fluid £15
Goodrich Braided Brake lines £60
Wheels + Tyres
Someone sold a set of Almost new TD 1.2's and Yoko Tyres for about £450 I think (they mite still be for sale on the forums)
So your talking 5k max all in for everything.
Im sure someone will try to point out something I have said wrong, but thats the way I see it.
And you dont have to do it all at once, I just did mine over a few months, well its still going....
Edited by chrisgold, 01 September 2010 - 07:50 AM.
#66
Posted 01 September 2010 - 08:06 AM
If it's just road then you defiantly don't need the 16/17 combo, suspension you could also leave and LSD you could probably live without (just easy with the right foot in the wet
and none of the above are pre-requisites to go to Stage 4, all can be done later as you push the limits of the car or become a bit more flush. 2nd hand TD's and Gaz suspension do pop up or group buys and you've got time to wait for a bargain.
EDIT: Yeah pretty much what Chris wrote
Edited by Bargi, 01 September 2010 - 08:07 AM.
#67
Posted 01 September 2010 - 08:40 AM
Stage 4
...so which of these garages you speak about fit clutches to a vx220's for £100 then??
#68
Posted 01 September 2010 - 08:46 AM
Stage 4
maybe they have £10 hourly rates, amazing what you can train a chimp to do
#69
Posted 03 September 2010 - 10:59 PM
Stage 4
£20 hourly rate, so even if they take a full 5 hours thats £100... What u think it takes 3 days to change a clutch?
#70
Posted 04 September 2010 - 10:14 AM
Stage 4
Lol you have clearly never changed a clutch in a vx then. The last two times I've taken the gearbox out, its taken me 2 full days and I've done it a few times now.
Vauxhall actually take take the engine out, but the box can be squeezed out below the car if the ns rear wishbones are removed, but then the geo will need to be done again. Good luck if you can get it done for £100, I would bit their hand off if they could do it for £300 - wish garages around here only charged £20/hr.
#71
Posted 04 September 2010 - 10:16 AM
#72
Posted 04 September 2010 - 10:18 AM
Stage 4
I bet they'd only do it once at that price!
#73
Posted 04 September 2010 - 12:54 PM
#74
Posted 04 September 2010 - 02:06 PM
I take it that was on a VXR turbo and not a standard VXT turbo?I found my stage 4 power delivery changed a bit over the course of time. When the car had a new turbo, power delivery was moderately smooth(ish), but after 5k miles I found the transition from no boost to boost was very on/off and made cornering tricky. That may have been because I got more used to the characteristics of the engine or because of wear in the turbo or some other minor fault (like a leaking vaccuum pipe etc). These titchy turbos we have really are at the very end of their limit at stage 4 and should really be upgraded to a slightly larger one IMO, but that of course incurs lost of cost, especially if you get to approx 310 BHP when you need to change the rods.
#75
Posted 04 September 2010 - 03:22 PM
It was with a VXR turbo, but I doubt there is any significant difference between them in reality.
#76
Posted 04 September 2010 - 05:11 PM
Typical time is around 8 hours. Good price from a grage is £300. Took me around 10 hours the first time, especially as i was on my own for most of it
8 x £20 = £160
Simples.....
#77
Posted 04 September 2010 - 05:15 PM
8 x £20 = £160
Simples.....
So wheres this garage that charges 20 quid an hour labour? Covering wages and running costs thats not really feasable
#78
Posted 04 September 2010 - 05:17 PM
Really? I thought the VXR Turbo was larger?It was with a VXR turbo, but I doubt there is any significant difference between them in reality.
#79
Posted 04 September 2010 - 05:27 PM
#80
Posted 05 September 2010 - 09:23 AM
