Updated M M G Stage1+ Map
#81
Posted 02 February 2016 - 05:14 PM
#82
Posted 02 February 2016 - 06:35 PM
Given your power background I guessed you'd quickly be tempted to go for a map Lee.Might be going for an MMG map in the spring, anyone had any issues over the years?
#83
Posted 02 February 2016 - 08:10 PM
#84
Posted 03 February 2016 - 09:48 AM
#85
Posted 03 February 2016 - 11:44 AM
#86
Posted 03 February 2016 - 11:45 AM
#87
Posted 03 February 2016 - 12:12 PM
Well no it doesn't , none of the tuners have bothered to make any improvements to driveability , the part throttle maps are all still terrible.
This is one area that I have spent months working every day to get this perfect.
Remember tuners are lazy and only bother to change a few cells for wide open throttle ignition timing , what works for them on a heavy Vauxhall rep mobile, is not suitable for a lightweight rwd sports car.
#88
Posted 03 February 2016 - 12:40 PM
Edited by LeeS, 03 February 2016 - 12:49 PM.
#89
Posted 03 February 2016 - 12:48 PM
Stage 1 makes a considerable difference especially mid range. Only thing required additionally for stage 2 is an updated exhaust and that's the expensive bit @around £1k...
Or get a used 2.5" system from somebody upgrading to 3"
http://www.vx220.org...ltek-for-turbo/
#90
Posted 03 February 2016 - 01:01 PM
in the grand scheme of things, the backbox makes little difference from stage 1 to stage 2. The turbine wheel is the restriction
common components not changed from standard to stage 1 or 2
- the standard intercooler does not get good enough air flow , so this is the limit
- standard k04-0024 turbo compressor wheel becomes much less efficient
- flywheel and clutch , this is the limit of overboost midrange torque
- probably the most important, the 'black' 370cc fuel injectors , they are at 100% duty , so no safety margin with these more optimistic high boost maps
worthwhile mods for any stage
- colder range spark plugs
- ally turbo intake pipe
- balance shafts delete
- 470cc vxr 'light blue' injectors
so taking all that in context , the map is not really solving problems itself, just causing new ones
#91
Posted 03 February 2016 - 01:59 PM
#92
Posted 03 February 2016 - 03:04 PM
Out of interest, what is the problem with the "part throttle" maps?
#93
Posted 03 February 2016 - 04:21 PM
#94
Posted 03 February 2016 - 04:39 PM
maybe we are talking about different things, the flat spot at 4000rpm?
#95
Posted 03 February 2016 - 08:30 PM
#96
Posted 03 February 2016 - 08:54 PM
#97
Posted 12 August 2016 - 10:11 PM
#98
Posted 13 August 2016 - 05:07 AM
#99
Posted 13 August 2016 - 07:12 AM
#100
Posted 13 August 2016 - 09:51 AM
