Good point John, i forgot about some of the incidentals....
1st Your quote of £9382.50 incl VAT dated23/3/2006 was superceded in Jan 2007 with the following..
Andrew,
Sorry mate, this website has taken a life of its own this week, I worked straight all night from Friday through to Sat night to try and break the work but I should be able to release it this week.
Right, the work on your car takes three stages, stage
1 (the chassis) is all pretty stright forward and is covered (details on costs in our stage 5 conversation)so thats charge cooler etc.
I cant remember what you've got on your car - its a stage 3 at the moment isn't it?
If so then all we've got to add is clutch, engine work and turbo.
Clutch will be about £1800 for the full deal - lightened flywheel Paddle clutch Labour, bearing etc etc
and that will all you'll need initially.
Stage 2 is the engine work:
Pistons £850
Rods - £650
Cams - £950
head work - £550
gaskets, seals - £200
Labour - 24 hours
As the engine has to come out for the clutch anyway I've put the labour in for that included in that cost.
Final part is the new turbo. Initially I propose we put an Astra VXR unit in there to run the engine in at that time I should be happy that mine is doing its job acceptably. Then we swap to the new turbo, manifold, intake pipework, remap, boost controller and all the gubbins which should be about £1800 all in. Still some conjecture on this bit of the work as Garet are now working directly with us on the project (due to the racing).
This equated to Stage 1
£950 Parts for Charge cooler
Labour for front clam removal/refit 6 * 65 £390
Clutch and flywheel parts £800 Labour covered in stage 2
The rear clam removal had to be done for stage 2 of the quote so is included in that part.
Total £2514.50 (incl VAT)
Stage 2
As above quote
Parts £3200
Labour 24 * 65 £1560
Total £5593.00 (incl VAT)
Stage 3
As above quote £1800
Total £2115 (incl VAT)
Grand Total £10222.50
I have got all but some of the stage 3 parts. I also took advantage of getting some other work done at the same time:-
Fitting of my guages - £261.31 incl VAT
Fitting of an LSD - £235.00 incl VAT
Suppy and fitting of rear wing - £1004.63 VAT
Total 1500.94 incl VAT
So whole job should be £11723.44
Bits that were added were a radiator covered by warranty (although I suspect there is a difference to pay as I opted for an alloy rad), an MOT and the long range fuel tank. I have no idea of the cost of all that but I would think it would be less than £1000 incl VAT
So maximum due when car completed would be less than £12723.44
The paint work was covered under a seperate invoice 10001168 (which also included a new set of rears) and I have not included this.
I did not get the Astra turbo to 'run in the engine' but that is by the by.
I have made 2 related payments:- 1 for £9988.50 and 1 for £1500 totalling £11488.50. TMS has written that I now owe a further £3000 as a final payment to conclude business. This would mean £14488.50 for the car 'as is' and it is nowhere near finished... Sure he says all it needs is a change of injectors and a re-map but that is clearly not the case when that is all it needed when it was with TMS the last time... for 9 weeks! And how much extra would that be?
I have since gone to Plans for an assesment of my car and replacement of the broken Engine mount.
It is now at Courtneys (having had a similar assesment) and I don't suspect they will carry out the remedial work for nothing.
I have not got a quote for the rear clam replacement or boot lid yet.
My point is that I don't feel I owe TMS anything. In fact if I considered all my unnecessary expenses then I believe TMS would owe me. I was prepared to come to an amicable agreement (which I thought we had, (see post 1)) and then I got the phone call.
I am preparing all my expenses now for the inevitable confrontation.
Edited by vxr36, 26 January 2008 - 01:54 PM.
