You've got your Turbo Gauge mounted in front of your starter button.
This is a problem because? lol
Posted 25 June 2011 - 01:28 PM
Posted 25 June 2011 - 01:39 PM
Posted 25 June 2011 - 04:45 PM
It's one way of saving petrol I suppose ..........if you can't start your engine.
Edited by P11 COV, 25 June 2011 - 04:46 PM.
Posted 25 June 2011 - 04:51 PM
Astravxr
Slight wheezing sound even off throttle + ticking when you start up until it gets warm (when the metal expands and closes the crack) is 99% a cracked turbo manifold
Posted 25 June 2011 - 04:55 PM
Thats not a turbo guage its a scanguage
Turboguage is to the right of the steering wheel.
Posted 25 June 2011 - 06:43 PM
Edited by iVXT, 25 June 2011 - 06:45 PM.
Posted 25 June 2011 - 08:58 PM
Edited by P11 COV, 25 June 2011 - 08:58 PM.
Posted 26 June 2011 - 02:10 PM
Thats not a turbo guage its a scanguageTurboguage is to the right of the steering wheel.
I was wondering if anyone can comment on comparing the Scangauge II with the Turbogauge III? Is one better than the other or got more features?
Turbogauge http://cgi.ebay.co.u...6#ht_3029wt_689
Scangauge http://cgi.ebay.co.u...2#ht_3257wt_922
Turbogauge is £20 cheaper. Found an older thread asking similar but no answers.
Cheers.
Edited by chrisgold, 26 June 2011 - 02:15 PM.
Posted 26 June 2011 - 02:18 PM
Posted 26 June 2011 - 03:42 PM
I love my Turbo Gauge, its amazing!
Gives an accurate BHP reading (within about 10bhp)
Posted 27 June 2011 - 02:29 AM
Best replace it with a vxr one then mate, I have a feeling Nev might have one knocking about so it might be worth a pm
Astravxr
Posted 27 June 2011 - 07:51 AM
Astravxr
Sorry to sound dumb but when you say changet the mani to a VXR one does that mean the VXR turbo too? My mate did a diagnostic test today and theres no error codes, i know a cracked manifold wouldnt come up as an error but if it was loosing that much boost wouldnt you get an error for that?
Posted 27 June 2011 - 06:19 PM
Well thats made Rolling roads extinct then. Why bother with all that complex machinary and expense when Turbo gauge can do it for you.
Posted 28 June 2011 - 02:06 AM
Well because rolling roads are used for mapping cars.
They also give out a lot more readings than just a bhp figure even on a power run.
But yes on the vx the turbo gauge gives an accurate bhp figure, accurate on several other cars also. It may be out by 20bhp max, but for a £90 tool its fcuking good!
have you never heard of an on the road dyno? Its a simple version of that. it takes all the readings fro the ecu (which is the main purpose of a turbo gauge to read the ecu) and calculates a bhp figure.
Posted 28 June 2011 - 06:56 AM
Did a better diagnostic test reading and i've found a code which is P1490 and all i can find is P1490 - Auxiliary Cooling Pump Relay Open Circuit. Is this a serious problem? This wouldnt cause boost problems or anything would
Posted 28 June 2011 - 07:47 AM
Slightly off topic- but does that mean it's not necessary to sit idling for 30s after a drive in order to let the turbo cool down?
Posted 28 June 2011 - 10:12 AM
Posted 28 June 2011 - 10:38 AM
Cheers
Posted 28 June 2011 - 12:53 PM
Posted 28 June 2011 - 12:59 PM
