Vx220 Vag Conversion - Dg Starts Something Different
#121
Posted 13 February 2012 - 11:18 AM
#122
Posted 13 February 2012 - 11:21 AM
The stresses on the bolts in that mounting arrangement shouldn't be much different to the original mounting approach.
Yes it is, its completely different.
On the standard engine,. the mounting is bolted on the engine on the horizontal plane. so the bolts are stressed along their length (which is what they are designed to do). on the above configuration there is now a sheer stress across the bolt, which they don't like at all. On the standard arrangement you also benifit from having a greater surface contact area which helps.
I can work out the stresses and strains if i had a few measurements, the rough weight of the engine, and the relative locations of the mounts to COG. Big enough bolts may take it, its just not very good practice imo. This might illustrate it better.
to qualify, I meant the stresses compared to the original mounting of the VW engine, not the Vauxhall engine. You can see the original mounting here:
#123
Posted 13 February 2012 - 11:24 AM
#124
Posted 13 February 2012 - 11:36 AM
#125
Posted 13 February 2012 - 11:49 AM
#126
Posted 13 February 2012 - 12:43 PM
#127
Posted 13 February 2012 - 02:34 PM
The sheer on those two bolts looks pretty unkind? I think i'd want some form of triangulation, or at least some form of mounting in the horizontal plane rather than the vertical. Great project though.
DG
Was raising my eyebrows too when I saw those mounting bolts. Like this they will see some massive torque load, like JG pointed out.
Edit; now saw the other posts. Still have my thoughts as the torque arm is a bit longer than then OEM VAG mount.
Edited by Exmantaa, 13 February 2012 - 02:37 PM.
#128
Posted 13 February 2012 - 02:43 PM
#129
Posted 04 March 2012 - 02:02 PM
#130
Posted 04 March 2012 - 02:07 PM
#131
Posted 04 March 2012 - 02:08 PM
#132
Posted 04 March 2012 - 02:11 PM
#133
Posted 04 March 2012 - 02:18 PM
#134
Posted 04 March 2012 - 02:20 PM
#135
Posted 04 March 2012 - 02:25 PM
From what Dg was saying there will be half inch spare at the back
Masses of space in DG land.
#136
Posted 04 March 2012 - 02:50 PM
#137
Posted 04 March 2012 - 02:56 PM
#138
Posted 04 March 2012 - 03:57 PM
#139
Posted 04 March 2012 - 04:00 PM
#140
Posted 07 April 2012 - 08:22 AM
