Brake Improvement Consensus
AP Bells Pads Nitron
148 replies to this topic
#21 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 05 February 2012 - 12:38 PM
removing the ABS will be an instant MOT failure from April 2012 thumbsdown
What's the reg Neil? How can they distinguish between that and cars that never came with abs?
#22 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 05 February 2012 - 12:40 PM
Ill look forward to your review on it. Whens your first trackday this year Jimmy, anything booked?
Bugger all yet George mate, I'm having a quiet one this year what with the little one but will defo do a couple of Pembray dates as they are cheap and great to shake the car down!!!
#23 vocky
Posted 05 February 2012 - 12:42 PM
A grey area, much like the airbag.
Being a hand built car means a friendly MOT station would pass it and another could fail it :glare:
#24 FLD
Posted 05 February 2012 - 12:45 PM
My friend has a marcos mantis. That's been recategorised somehow as a kit car. He has no problems not running a cat etc. I wonder if we could get that reclassification??
#25 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 05 February 2012 - 12:46 PM
With regards to the upgrade I did say in my original post that I would suggest the new servo/master cylinder to be implemented with the abs module so in 99% of examples the abs would remain in tact. Mine's screwed though :lol:
#26 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
My airbags gone too, defe screwed :lol:
#27 chris_uk
Posted 05 February 2012 - 12:52 PM
You cant just look at discs, calipers and pads for better braking.. You also need to take into account the size and type of tyre you are using. In reards to the master cylinder, if you fit the ap racing calipers with the small and large piston and fit the front calipers on the rear the master cylinder can cope just fine. I had problems when the front 4 pots had 4 large pistons and then the master cylinder was just able to cope, i probably wouldnt of tracked it. There are other aspects such as braided hoses, brake fluid and what type, also what temperatures the fluid is capable of handling.
#28 vocky
Posted 05 February 2012 - 12:53 PM
the MOT station has to prove it's obviously missing, so if it's not obviously missing they cannot fail it - I asked my local MOT station the other day :sleep:
#29 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 05 February 2012 - 01:31 PM
I think the problem is with the light bulb. It will illuminate when the stack fires up and will therefore show that's it's obviously missing. Removing the bulb will also be a fail. Can the stack be split and the abs writing be removed...?
#30 vocky
Posted 05 February 2012 - 01:38 PM
if the light is off and the equipment is not fitted (like the airbag or abs) then it's not a fail, they accept that not all cars will have all the options. example: many petrol cars have the diesel glow plug light installed in the dash, but obviously don't have glow plugs :P
#31 Rally
Rally
  • 650 posts
Posted 05 February 2012 - 01:39 PM
Of course, if you were very sneaky, you could redirect the black and yellow wire from the dash to a timed relay so that the ABS LED would light up and go out just as if the ABS unit was still there. Just saying...
#32 The Batman
Posted 05 February 2012 - 01:51 PM
If only there was friendly mot people out there
#33 alanoo
alanoo
  • 1,324 posts
Posted 05 February 2012 - 01:55 PM
Where is option 6 ? Fit a proper pedal box with a balance bar, 4 pots on the front and 2 pots on the rear ? At least, that's what I'm doing on mine... ;)
#34 Rally
Rally
  • 650 posts
Posted 05 February 2012 - 01:57 PM
Where is option 6 ?
That is clearly the best option of all :) The trouble will be MOT, insurance and if you have to sell the car.
#35 alanoo
alanoo
  • 1,324 posts
Posted 05 February 2012 - 02:17 PM
Yep true, mine is not a road car anymore :(
#36 techieboy
Posted 05 February 2012 - 02:26 PM
Why stop at 4-pots? I've got a nice pair of RS4 8-pots in the garage. :lol:
#37 robin
robin
  • 3,810 posts
Posted 05 February 2012 - 02:31 PM
Option lots of dosh! Carbon discs gt3 calipers woof woof!
#38 OneYet
OneYet
  • 1,355 posts
Posted 07 February 2012 - 06:45 AM
There are now a rather large number of options aren't there?
I'm going to try and arrange them in a way that makes some sense and then if you've experienced some of them, it would be great to get your views.
Your thoughts ladies and gentlemen. :D
Well folks.
What are your opinions about the BRAKES? :rolleyes:
#39 SteveA
SteveA
  • 9,159 posts
Posted 07 February 2012 - 11:30 AM
As I see it you can upgrade your calipers to 4, 6, 8 pots and it's not gonna make any significant improvement as you are still putting the same force into the circuit just spread across more pistons. I think a MC upgrade coupled with more pistons is one of the few ways to seriously improve things. Not that I've ever found the std 2 pot fronts lacking.
#40 Dashwood
Dashwood
  • 494 posts
  • Interests:discussion
Posted 07 February 2012 - 11:46 AM
What about Porsche brakes and a Subaru master. here
Should make Seloc meetings a bit more interesting. :D
