Brake Improvement Consensus
AP Bells Pads Nitron
148 replies to this topic
#41 LazyDonkey
LazyDonkey
    Lotus imposter
  • 7,748 posts
Posted 07 February 2012 - 01:23 PM
You've not mentioned refurbing the OEM calipers. As the cars get older people may be tempted to upgrade the brakes when they could benefit from a refurb first of all. My car was transformed by refurbed Ap's.
#42 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 07 February 2012 - 01:24 PM
Did you do this yourself...?
#43 LazyDonkey
LazyDonkey
    Lotus imposter
  • 7,748 posts
Posted 07 February 2012 - 01:26 PM
Good god no - i don't know one end of a spanner from another :D Local specialist sent them away to be refurbed, can't remember how much it was but it wasn't that expensive.
#44 Boombang
Boombang
    Saxo boy
  • 3,022 posts
Posted 07 February 2012 - 04:13 PM
I refurbed mine on the car Trifid bought. Was very simple and the effect was massive. It was mainly as when came to do the brakes they were completely full of old brake dust, even though the pads weren't all that old. The garage apparently hadn't heard of copper grease either (although I used the Mintex stuff personally).
#45 vocky
Posted 07 February 2012 - 05:09 PM
I run AP 4 pots up front, with 308mm astra gsi discs, standard rear calipers and Mintex 1144 pads all round. I prefer the feel this set up gives to the brakes, plus with the greater front pad area and larger front discs they should stay cooler for longer :sleep:
#46 Bargi
Bargi
  • 4,483 posts
Posted 07 February 2012 - 05:38 PM
how much heat can you get into a brakes if all it does is sit in the garage??? :P
#47 vocky
Posted 07 February 2012 - 05:40 PM
damn I've been sussed :P
#48 chris_uk
Posted 07 February 2012 - 05:45 PM
:lol:
#49 OneYet
OneYet
  • 1,355 posts
Posted 07 February 2012 - 07:02 PM
Those 308 mm Astra Gsi discs. Is that more or less the same as the SAAB Aero discs thet where much hooing about 5 or 6 years ago?
#50 vocky
Posted 07 February 2012 - 07:15 PM
I believe back then it was using the standard 2 pots with 11mm spacers, but otherwise they are basically the same disc
#51 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 07 February 2012 - 08:54 PM
I belive so, check mekonomens homepage
they have drawing of the brake discs there of most of the brake disc.
#52 JG
JG
  • 13,617 posts
Posted 15 July 2012 - 09:01 PM
For Rob :) In the end i went for: AP racing 4 pot fronts (£550) Ferrodo DS2500 front and rear (which i really really like - apart from they smell when hot) (fronts FoC with calipers, rear £130) CRN 308 standard discs (with bling J hooks for looks /runs and hides) (£70) CRN standard rear discs (with matching J hooks) (£50) Braded hoses all round (£40) Dot 4 high temp fluid (£20) 4 channel ABS Unit (£400) Replacement vac hose (£75) £1335 :o oops, wish i haddn't just done that.
#53 JG
JG
  • 13,617 posts
Btw, they were absolutely fantastic at Anglesey. Stops on a six pence. and you can just stand on them.
#54 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 15 July 2012 - 09:02 PM
Cheers James. It was never my intention to get you to detail the costs involved...no honestly!! :P
#55 JG
JG
  • 13,617 posts
Posted 15 July 2012 - 09:11 PM
oh and i'm pretty sure i could have achieved what i did, with the VXR abs unit alone. :rolleyes:
#56 techieboy
Posted 15 July 2012 - 09:15 PM
Yep, I reckon so, too. :wacko:
#57 robin
robin
  • 3,810 posts
the four pots are the best upgrade on brakes not once did they fade at anglsey along with new rear calipers imo makes the braking as good as it will ever be.
#58 CocoPops
CocoPops
  • 17,182 posts
Posted 15 July 2012 - 09:17 PM
So I'm running standard brakes with 4chan abs ecu and rs14 pads. I'd like to chage discs to something lighter, reduce unsprung weight... What are my options? Didn't get brake fade Robin, even with standard front calipers and increased corner entry speeds with SCing.
#59 JG
JG
  • 13,617 posts
Posted 15 July 2012 - 09:20 PM
The elise parts discs. or the 29something discs with caliper spacers.
#60 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 15 July 2012 - 09:24 PM
Apart from Paul, has everyone bored off 308 discs? I know they would require spacers....
