So the result, old system:-
(This is a 4th gear drag from 3000 rpm upto speed X)
And the same drag on the new system.
The result is 10 degrees off the IAT. - You can see the graph is less steep on the 2nd plot too.
And now for my next improvement I've bought this:-
http://www.ebay.co.u...984.m1439.l2649
(25l/min pump)
To give you an idea, my Aussie pump flows 12l/min @ 5PSI
The Bosch one everyone has flows 20l/min @4.5 PSI
And this one flows 25l/min @11PSI.
Its often stated that the bigger the pump isn't necessarily the better - this may be true for the radiator side as you might not have time to take all the heat out of the water. - But the answer to that would be a bigger rad not reduced flow!
At the heat exchanger it should help by providing more cool water thus increasing the temperature differential which is the main governing factor in heat exchange. - You also want fluids to have turbulent flow for heat exchange, otherwise there is an insulating boundary layer of stationary fluid against the walls of the tubes.
Edited by JohnTurbo, 28 April 2012 - 05:20 PM.
