Bit of a slow reply, but the hole is 12mm.
@Chris - AVT chargecoolers are no better than what I have, and 4x more expensive. There is a thread on here somewhere where someone tried it and the results were very disappointing.
So I have been playing again today.
This is the entry to the STOCK IC:-
This is the entry to a stock IC after an hours work:-
It still looks tight. - That said compared to air flowing at atmospheric pressure, my car runs at say a "bar of boost". The mass flow rate of the tubing will be approximately double, but the volumetric flow rate would be about the same. This is quite a nice side product of the turbo. - You get more air and fuel in the cylinder, sure, but you also get more air through the same diameter of pipework. -This is different to the exhaust side, where as little back pressure as possible will give the turbo more 'oomf'.
....So I figure Its worth a go. The TMS CC runs after the stock IC, and I will do the same.
I've also noted Simon and Duncan are making a really nice job of the same layout, only for a much higher power than I'm after.
So, looking at the picture below:-
* Stock IC with enlarged entry is refitted with all correct ducting, and foam to fill the gap between IC and clam.
* My neat little CC core fits nicely in-line between the tophat and the stock IC.
* The water plumbs in fine, and I've trial-fitted the wheel arch liner and it doesn't foul.
Jobs to do:-
* Mod the CC outlet to take the TMAP sensor. 12mm hole!! ;-)
- Otherwise the intelt temperature would be wrong and thus the fueling and advance.
* Extend the TMAP sensor wiring so it will reach.
* Chop the IC -> Tophat hose and fit it to the CC exit.
* Device some way of securely strapping the CC to the subframe butress/stay.
