Engine Mount Major Problem
77 replies to this topic
#21 starlight
starlight
  • 1,790 posts
  • Interests:Oily bits...
Posted 19 April 2012 - 01:40 PM
Has your car ever had a rear shunt or been in a front end accident? I've seen the rear engine mount from the rear subframe bent on one car that I did not buy. This will have the effect of pushing the engine forward and adding extra shear force on the mount.
#22 Apex Graphics
Apex Graphics
  • 294 posts
  • Interests:Boxing, Golf, Waterpolo & Cars!!
Posted 19 April 2012 - 02:00 PM
No not that I'm aware of. it's not registered and has all original parts, nothing looks out of the ordinary at all when up on a ramp and I've had a few people look who know VX's very well. We spent about 5hrs under it last night doing various things!! It's very strange, I'm waiting on a mechanic friend of mine who works at Vauxhall to send me a picture of what he can supply as an original Near side engine mount, he can get them for £60.00, usually they are £80+ to the general public.
#23 frankandbeanz
frankandbeanz
  • 46 posts
Posted 19 April 2012 - 02:13 PM
ok have some measurements, the old engine mount is 850mm high the new auto vaux one is 700mm high
#24 techieboy
Posted 19 April 2012 - 02:15 PM
70mm is correct
Ignore the fact this is an upgraded aftermarket mount, the dimensions are exactly the same as the originals
#25 frankandbeanz
frankandbeanz
  • 46 posts
Posted 19 April 2012 - 02:21 PM
Ok so the old one i took off has been stretched?? 150mm seems a lot, it is also a lot bigger in diameter then the autovaux one? The 200 yd test drive was quiet until bang grrrr.. strange thing though the guy previous said he has had this engine mount noise for 4 years??
#26 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Posted 19 April 2012 - 02:28 PM
How odd, Is the mounting bracket bent or non OEM?
#27 fezzasus
Posted 19 April 2012 - 02:34 PM
70mm is correct
Are you running vibrasonic mounts too? any impressions? my maths says that I should use them next time I need to replace my mounts anyway - plus I imagine they are similar to adding the poly inserts in terms of engine movement
#28 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 19 April 2012 - 02:39 PM
They is a lot less movement verses the poly insert option ;) DG
#29 Apex Graphics
Apex Graphics
  • 294 posts
Posted 19 April 2012 - 02:41 PM
OK so I don't know how to upload images but the exploded diagram I just got faxed from Vauxhall shows a different engine mount than the one in the picture above ( I know it's aftermarket ) The one form Vauxhall is allot more bulky and bigger just like the one we took out last night...... It's Vauxhall part no 93172350, I need to show image but I don't know how!!!!
#30 techieboy
Posted 19 April 2012 - 02:45 PM
Nope. I didn't bother fitting them as I wasn't sure they really were an upgrade. There seemed to be more movement in them, than in the standard mounts.
#31 fezzasus
Posted 19 April 2012 - 02:50 PM
One theory: the engine mounts have changed since the factory fitted mount, either due to supplier differences or to actually address the failures. If you only fit one, then you introduce an angle directing the force towards the new mount, increasing chance of failure. Replacing both removes this angle and puts it back to the original positioning, abit 15 mm lower. This will also change the bulk of the engine supporting from the top mounts to the bottom mounts, which are not known to fail. My guess is this is actually an improvement on the original based on the drop in height, but only if applied to both sides.
#32 Apex Graphics
Apex Graphics
  • 294 posts
Posted 19 April 2012 - 03:05 PM
We fit new ones to both sides and it tore the near side one apart inside 1 mile!!
#33 slindborg
Posted 19 April 2012 - 03:06 PM
850mm and 750mm........ someone has their units wrong
#34 Apex Graphics
Apex Graphics
  • 294 posts
Posted 19 April 2012 - 03:15 PM
He meant 85 & 75!!
#35 frankandbeanz
frankandbeanz
  • 46 posts
Posted 19 April 2012 - 03:19 PM
duh! finished at 2am not feeling good, 75mm i think gonna have to put it back on ramp and check middle mounts as the engine sits 15mm higher on the NS then standard il take a picture of this tonne of rubber and post it on friday..
#36 frankandbeanz
frankandbeanz
  • 46 posts
Posted 19 April 2012 - 03:22 PM
ok to add to more confusion just been faxed diagram from vauxhall dealer the OS bracket is pictured in fax with 3 13mm bolts going into engine horizontally, but i can remember last night there were 3 13mm bolts holding the bracket to the engine vertically can any body clarify..?
#37 Phear
Phear
  • 1,125 posts
Posted 19 April 2012 - 03:26 PM
If memory serves the Near Side ones are horizontal into the block, the offside are vertical into the gearbox. Thats on an N/A anyway.
#38 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Photos of your current set up would help a great deal. thumbsup
#39 hughcam
hughcam
  • 730 posts
  • Interests:driving, motorcycling, snowboarding, v12 lawn mowers
Posted 19 April 2012 - 03:30 PM
I have a brand new Mount in Packaging if your interested. Can send it tommorrow 1st class if you need it for the weekend - £30.00 plus postage
#40 techieboy
Posted 19 April 2012 - 03:32 PM
NAPosted Image
Turbo
