Shawspeed Kit Car Project
201 replies to this topic
#161 Thealastair34
Thealastair34
  • 988 posts
Posted 10 July 2013 - 08:49 PM
I love this thread please do not stop.
only going to get better!
#162 Thealastair34
Thealastair34
  • 988 posts
Posted 11 July 2013 - 08:19 PM
more engine work tonight, checking everything and torquing it all to make sure al is fine.
not much to show but enjoyable and gives peace of mind
#163 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 11 July 2013 - 08:52 PM
Are the red blobs so you can see if something has loosened? Or do you spanner with a nosebleed?
#164 Thealastair34
Thealastair34
  • 988 posts
Posted 11 July 2013 - 10:13 PM
Yes, just so it's easy to check as everything vibrates a lot
#165 Thealastair34
Thealastair34
  • 988 posts
Posted 13 July 2013 - 02:01 PM
block back in
need to get the right piston ring next week for it then i can get the sump and head back on and get it running.
decided to build the head back up ready to drop on while im waiting for that ring
#166 Duncan VXR
Duncan VXR
  • 5,283 posts
Posted 13 July 2013 - 07:10 PM
How did I miss this thread? Epic stuff B-) DG
#167 Thealastair34
Thealastair34
  • 988 posts
Posted 13 July 2013 - 09:26 PM
thanks,
might see you around in yours!
#168 Thealastair34
Thealastair34
  • 988 posts
Posted 20 July 2013 - 08:50 PM
more work done today,
pistons back in
dry sump all cleaned and and refitted
[/URL]
bottom end
new headgasket
head back on
turbo cooling lines refitted
alternator and dry sump belt on
also cut bonnet vents out and meshed them to get air out of the bonnet
Edited by Thealastair34, 20 July 2013 - 08:51 PM.
#169 RabnaKS
RabnaKS
    If anyone can talk Bllx, I can!💣
  • 2,717 posts
  • Interests:MTB, VX220, oh & cars, golf, sarcasm with humour!
Posted 20 July 2013 - 09:52 PM
Al, Now I see why you've not bothered doing the window wobble, too trivial!!!!!! You're a genius.  A future 'how to book' for your pension?
#170 Nev
Posted 21 July 2013 - 12:46 PM
Blimey that head gasket looks nice.
#171 Thealastair34
Thealastair34
  • 988 posts
Posted 21 July 2013 - 03:52 PM
a fair bit done this morning, just needs cams in and timing up and its ready to go again
sometime this weeks jon is coming from shawspeed to retime it all up
out for a wash today
mascot sill it one piece
#172 Thealastair34
Thealastair34
  • 988 posts
Posted 23 July 2013 - 08:38 PM
back in the game
needs a spanner check and some more engine oil then im good for a road test
#173 Thealastair34
Thealastair34
  • 988 posts
Posted 08 September 2013 - 08:34 AM
afew clips
car going well, have a weeping axle that needs looking at this week just retaxed it too, not sure how much ill use it as it gets colder though!
#174 Thealastair34
Thealastair34
  • 988 posts
Posted 22 December 2013 - 11:44 AM
been a while,
anyway went out a month or so ago and clipped the rev lmiter and it stopped working
free ride home then found the cause,
new cam thanks to shawspeed and piper for making it quickly
fitted
made a carbon footwell cover, needed to do this to firewall the car so i can past testing
also making a new bottle and mount
and plug lead cover
mount made
#175 Thealastair34
Thealastair34
  • 988 posts
Posted 15 February 2014 - 06:31 PM
nearly finished the carbon dash front and rear, just to neaten the edges
also made a carbon spark plug cover to make that look nicer
thing about making some vented side panels to help with cooling and im also redoing the fuel system with -6 aeroquip throughout in the next few weeks
#176 Duncan VXR
Duncan VXR
  • 5,283 posts
Posted 16 February 2014 - 07:10 AM
Looking good as per usual! Going to get my track beast out early this year on track and want to do some work in advance DG
#177 Thealastair34
Thealastair34
  • 988 posts
Posted 19 February 2014 - 08:06 PM
thanks, im just potter on improving areas i know are not perfect
#178 Thealastair34
Thealastair34
  • 988 posts
heat has allows been a concern for me in such a small compact bay
my oil temps in there current setup fair ok for road use but rise quickly after afew 8-10 full boost blasts enough to know that sustained track work will cause me some issue, also the cooler the oil the higher oil pressure which is good
my plan is to move the oil cooler and turbo cooler to outside the engine bay onto the side panels in clear air, they will be located in alloy covers and i will have one o feach side which also helps reduce he pressure drop in the oil lines as they will be shorted
to help with this i needed to make the side panels more taught so started to refit a flat floor setup, still needs some work and a engine inspection panel making for the centre
current setup
floor
chopped modded and fitted roughly
#179 Thealastair34
Thealastair34
  • 988 posts
Posted 21 February 2014 - 08:37 PM
little more work tonight, sorry for poor pic quality
rad and cooler off to reveal turbo cooler
turbo cooler removed, oil cooler left in for now, you can see how tight it is for space its fair to say
basically my aim to to mount both cooler on each side of the car like th below pictures will illustrate, they will be covered in by alloy to channel the air in and out, further to this is i plan to have a extended floor section to also help remove hot air from the bay into the oil/water cooler low pressure area
that is that plan anyway
cooler a this oriantation, with the inlet facing inwards of course
another advantage is the shorted oil cooler lines, they will go from 3 foot there 3 foot back to 6" each so i should have a higher oil pressure in theory
will make the templates for the alloy side pods from card this weekend all being well
#180 Thealastair34
Thealastair34
  • 988 posts
Posted 24 February 2014 - 07:54 PM
afew more bits done over the weekend
coolers mounted
will be the other way round but working out measurements
fastened on with performace duct tape and card
