Project Ginge
298 replies to this topic
#41 gingerjon
gingerjon
  • 587 posts
Posted 20 April 2013 - 05:45 PM
Ok cool, Thanks Joe, i thought that would be the case. Unfortunately its on so tight on the old one i'm struggling to get it off! Yep, i had thoguht about the 2.4 manifold but i'm hoping to have you and Lee work the SC magic on it towards the end of the year before it goes back on the road so seems a bit of a waste, unless of course i put if on and you'll swap it for an SC? Then i'm going on the hunt now!!! :happy:
#42 The Batman
Posted 20 April 2013 - 05:48 PM
always the way! had the same on my engine, never come off when you want them to :9mm: :lol:
#43 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 20 April 2013 - 05:58 PM
Well done sir! Hope the fly wheel sees you well.
#44 Nev
Posted 20 April 2013 - 07:20 PM
Blimey, lots of work gone on there. Now come round and help me do the same on mine! LOL Where did you get your clutch cover from BTW, as I haven't seen a red one before.
#45 vocky
Posted 20 April 2013 - 07:23 PM
something wrong with that clutch cover, the 'fingers' are way too far in :huh:
#46 vocky
Posted 20 April 2013 - 07:26 PM
also don't forget to transfer the vx220 specific oil blanking mechanism inside the oil filter housing
#47 Nev
Posted 20 April 2013 - 07:35 PM
something wrong with that clutch cover, the 'fingers' are way too far in :huh:/>
Maybe it's an X20XEV or C20LET one?
Edited by Nev, 20 April 2013 - 07:37 PM.
#48 Arno
Arno
  • 1,238 posts
Posted 21 April 2013 - 10:52 AM
Or clutch plate mounted back-to-front? Bye, Arno.
#49 gingerjon
gingerjon
  • 587 posts
Posted 21 April 2013 - 05:20 PM
Clutch was definately for an N/A.....i checked this morning :blush: After speaking with Vocky Imnotworthy , i'll double check the fin measurents next weekend and may have to revert back to the old clutch cover. Nev, i have the mechanical nouse of a badger.....but i'll trade taking your car apart for you*......for nice engine! :D *I cannot gaurantee i can put it back together again as i will no doubt prove on mine over the next few weeks :wacko:
#50 gingerjon
gingerjon
  • 587 posts
Posted 07 May 2013 - 08:33 PM
With a spare Saturday morning on my hands, down tot he workshop i went!
After the confusion with my clutch cover, i removed the new one from the new engine and measured it up wihtt he one that was on the old engine. The "Fingers" were exactly the same length and th cover near identical. I'm not sure if it's not just an OEM one sprayed red!!!
I then re-aligned the clutch and cover and re attached to the engine. Then after what seemed like an ice age......it happened....
The cars heart transplant was complete....ish!!
Engine back in, new mounts in place and a load of things to plug back in!! Only slight issue is that the new pulley tensioner didn't arrive in time so i just hope i can get it onto the side without taking it all back out again!
#51 gingerjon
gingerjon
  • 587 posts
Posted 07 May 2013 - 08:43 PM
The new Engine seems a lot cleaner of general gunk than the old one, Cliffie must get the credit there!
And after a swift stop on Firday to the home of the shinest V (But a little poorly upon arrival) VX in town....a purchase from JG wasn't fitted just yet, but it was so clean i couldn't resist a picture!
Now the next large chunk of cash is needed. order to be placed this week for :
Brake discs and 1144's
Brake fluid
Tensioner pulley (When it arrives!)
Engine Oil
Lambda sensors
Aux Belt
Oil filter
Spark Plugs
Rocker gaskets
Battery
and last but not least and most expensive....a pro alloy rad (I just can't bring myself to take a punt on the chinese ones on eBay!!)
Hopefully over the next couple of weeks when it all arrives and if i can remember where everything goes, she may eventually start.
The plan was to have the engine running before i head off to Le Mans next month, fingers crossed i'm still on target!
If anyone has anything on the list above....feel free to OM me and save me some money! :)
Jon
#52 Goosenka
Goosenka
    Jeep Driving jolly nice chap
  • 12,716 posts
Posted 07 May 2013 - 08:48 PM
Jon I have some used 1144s which have good depth left on. No worries if you are after new ones.
#53 vocky
Posted 08 May 2013 - 10:27 AM
did you measure the installed height of the clutch covers and have you bled the clutch and tested it works - I always check the clutch works as soon as two bolts are in the bellhousing.
#54 gingerjon
gingerjon
  • 587 posts
Posted 09 May 2013 - 07:24 PM
Yep both clutch covers were the same, not filled the systems as the brakes and ABS unit are not hooked up yet so cant test it. Goose, thanks the offer, i may well take you up on those, ill look for some discs and let you know. Jon
#55 gingerjon
gingerjon
  • 587 posts
Posted 19 May 2013 - 10:44 AM
With a bundle of new shiney bits arriving from variouos places this week, it was time to get back into the overalls!!
New Disc's and 1144's
New Tensioner Pulley
New Belt
Oil FIlter and a rocker cover gaskets set
Started by fitting the new disc's, not fitted the pads yet though as need to get some copper grease.....which i'd forgottern!
Nice to finally see the rust and crud removed from the old girl!!
With the rear drivers wheel off, i set about the new tensioner and belt for the alternator....
How on earth do you tighten it up into position to keep the belt tight? I could not get the lug into place and tighten up?
Muppet moment!
#56 gingerjon
gingerjon
  • 587 posts
Posted 19 May 2013 - 10:49 AM
Old Oil Filter seemed in good nick, but for the sake of a couple of quid, was worth changing "Whilst i was ther"....god that phrase is haunting me!!!
And thats how i left it, after a clean up of a massive pile of boxes and wrapping of new parts, the garage was a little cleaner. Still a long way to go however....
Now the dilema, i'll post up seperately!! :blush:
Jon
#57 Ormes
Ormes
  • 4,612 posts
Posted 19 May 2013 - 08:24 PM
Nice work thumbsup
#58 gingerjon
gingerjon
  • 587 posts
Posted 01 June 2013 - 05:45 PM
Okeydokey, after a moment of doubt last week, i went straight back to it this week!
Firstly, Thanks to Tom220 for spending the cash i had saved for the new Pro Alloy Rad!! :happy: I suppose that will need to wait till next month!!
Luckily i was already heading up to the North so was able to collect the bits en route. Neither of the bits i bought i ACTUALLY need at the moment....but i couldn't resist!
I wanted a hardtop for the car but the OEM one i have is pretty heavy and in too good a condition to chop up. When Tom mentioned he had this one from an Exige for sale i went for it, meaning i don't mind modifying it for weight and also my OEM Hard Top can then be sold to someone who will actully get some use out of it!
The scoop won't go to anything at the moment, i'm not doing the bodywork for a while yet so have some time to ponder the options!
Second on the list was the Jimsan Diffuser, i have always really liked the shape of the side profile compared to some of the others, they don't come up often and even though, like i said, i don't need it for some time....it was good to snap one up!
Once i had finsihed pretending i was further down the process than i was :blush: .....i cracked on with the engine.
First up was the pulley tensioner issue i had last week.... After removing this, tightening and loosening that i was getting nowhere so i took the whole pulley off for a look and the solution hit me in the face with a stupidity punch i deserved.....
With the pulley in its correct position and tightend, i put the belt round the lower pulley, a socket drive into the "Square" on the Pully and twisted bringing the spring action up, looped the belt over the altenator and released. All tight and correct. Only took 2 weeks to fathom out!! :sleep:
Edited by gingerjon, 01 June 2013 - 05:49 PM.
#59 gingerjon
gingerjon
  • 587 posts
Posted 01 June 2013 - 06:02 PM
No the questions.....feel free to throw any advice my way, on some occasions i will accept being called a dumbass.....
Are these wires on the Starter Motor the right way round? I have since swapped them over, but have seen them in images on the net both ways round....confusing? :mellow:
Whats this? It's on the same wiring bit as the starter motor but looked briken to me and i can't work out where it would go?
Whats this? and where does it go? It seems to reach all the way over towards the coolant tank....
Where does the other end of this one go? It comes out of the Rocker cover and round the back along the bulkhead following the pipe for the collant tank
Where does this sensor screw onto?
Thats your homework for today, answers on a postcard, thanks in advance for the help  :grouphug: I genuinely thought i had bagged, labelled and marked up everythign enough to just "Pop" it ll back together!
I finished by test fitting the exhaust with the new manifold, i need some new bolts for the manifold but it looked more like a car that may one day start again than it has for a good few months!!!
I was planning on wrapping the exhaust with the material head shielding you can get, has anyone done it here? fancy passing on the "How to"?
With Le Mans only 3 weeks away, my target was to at least have the engine running before i went, looks like i may slip slightly behind that date but hopefully not by too far!!
#60 CHILL Gone DUTCH
Posted 01 June 2013 - 06:06 PM
I think the pipe with the funnel thing in the end is the breather , There should be a other bit in the bottom
