Zac I am not letting it out the garage that cheap!
DG
Posted 07 August 2013 - 10:49 AM
DG
Posted 08 August 2013 - 02:08 PM
Posted 10 August 2013 - 08:07 PM
You have a pm
Zach
You have another PM.
Posted 24 August 2013 - 09:32 PM
Sold, pending payment.
Posted 29 August 2013 - 09:25 AM
The engine, Garret, CMS exhaust manifold and Dave Hardwick intake kit are now for sale again. £1500 for everything and available for collection from Coventry.
Zach
Posted 29 August 2013 - 12:58 PM
mbes might be interested , would a lot cheaper to have a proven build than buy all the bit seperate and then have an engine builder install.
Posted 30 August 2013 - 01:31 PM
Turbo, Manifold, Actuator and Intake Kit are all sold pending payment.
The engine is still available.
Just to recap its spec
Oem LEH head
Multi layer standard compression head gasket
Practicly new coil pack
Fully forged, rebuilt and balanced LET bottom end
Mahle Pistons
Arrow Con Rods
Head stud conversion
New cambelt kit
New water and oil pumps
New Mahle Up rated bearings throughout
Balancer Deletion Kit
Roughly 6000 Miles
Cool Running plugs
Bottom end is painted red
Top end cover is also painted red, but is easily replaced with an OEM cover.
Now for the bad bit. The engine is in perfect working order. However, it is smoking. After a compression test, cyclinder two was found to be lower than the other cylinders so I suspect it requires a a new piston ring and re-hone of cylinder two.
For someone that has the knowledge or who would like to use this as a project to tinker with an engine that already contains all the best parts available, it is a perfect opportunity to save alot of cash especialy as the engine is already out and easy to work on.
£1000 ovno with collection from Coventry/ + postage
Zach
Posted 30 August 2013 - 02:05 PM
Posted 30 August 2013 - 04:31 PM
Posted 31 August 2013 - 05:40 AM
Posted 31 August 2013 - 08:00 AM
Else ill just have it checked out, fixed and then put it up for more money as a guarenteed engine. Zach
I'd expect it'd be gone very quickly (even at higher money) if this was sorted
Posted 31 August 2013 - 08:07 AM
thats the only thing stopping me , the uncertainty of #2 and potential damage. If only the head was taken off to inspect, worst case this confirms the bad news and its worth not as much , or its just a HG
Posted 01 September 2013 - 08:13 AM
General Discussion →
Tuning & Modifications →
Projects →
Vx Turbo ProjectStarted by Hopey , 06 Mar 2017 ![]() |
VX220 Discussion →
Cat B 325 Bhp Vx220 Turbo For Sale On PistonheadsStarted by PaulM , 01 Jan 2016 ![]() |
Projects →
Project Frankenstein - C20Let Vx220Started by CraigyT , 04 Jul 2015 ![]() |
