my effort, slight throttle lift then back on the power
Posted 16 June 2013 - 02:15 PM
Posted 16 June 2013 - 02:43 PM
Edited by Firthy, 16 June 2013 - 02:51 PM.
Posted 16 June 2013 - 03:13 PM
Posted 16 June 2013 - 03:14 PM
Posted 16 June 2013 - 04:53 PM
I had touched on it. Diconnecting the drive is key as even though after a lift, the engine will still be spinning at 3k rpm(or whatever) and therefore spinning the rear wheels at that speed through the gearbox. Very snappy and effective is the old cadence clutching. It's amazing how much speed gets scrubbed off without the engine pushing on. Far too many variables to say what THE solution is, even just road Vs track is such a different style with infinitely less margin for error on the road. You don't need a big hero drift, you need the car back in check as quickly and safely as possible when on the road. Some top saves on track above!!has cadence clutching been mentioned yet?
Posted 16 June 2013 - 06:06 PM
I was expecting something more along the lines of "fingers down the throat and hook the bastard out" ...
Posted 16 June 2013 - 09:08 PM
Posted 17 June 2013 - 11:09 AM
In a straight line a gentle lift to get traction bacl AKA Snetterton last year in the wet on the Bentley Straight.
In a corner, oppo and plant it.
Posted 17 June 2013 - 11:37 AM
I remember you saying that to me when you got back in the pits (from winning ). It saved me a couple of months later when exciting a motorway on trailing throttle, got half way round the bend and the rear end tried to overtake me, so i planted it at first to catch the slide then gradually came off the throttle as the Vx straightened up.
Then pulled into the next services to check my pants
Posted 17 June 2013 - 12:49 PM
Who's the laughing man Firthy?
Its my friend Will... I had been chasing him for a few laps so he pulled over to let me passed and of course I went in too hot!
Druids is lethal in the wet though with the surface change ..... very little grip
Posted 17 June 2013 - 03:49 PM
Posted 17 June 2013 - 10:03 PM
Getting back to the original question. If in doubt put the clutch to the floor. Instantly the problem that is causing the rear to come round is gone. Rear tyres now have maximum side grip ie neither accelerating or decelerating - just don't overcompensate with the steering as the rear comes back in line.
It is the simplest thing to learn about the VX.
Kind regards, Paul
Posted 17 June 2013 - 10:30 PM
If you want to save a big slide in a vx you need fast hands here's a big moment from Oulton earlier this year. Having harnesses / a proper seat enables you to have instant feedback and you need that feel... Notice how quick I wind the lock off to stop the fish tail.... this is what you need to do to stop the car sliding back the other way into a fish tail....
Ace driving meant that was a rear end slide not a fishtail. Great. Paul
Posted 17 June 2013 - 11:43 PM
Posted 18 June 2013 - 07:19 AM
Ah Steve, his book was good, wasn't it? It's only a matter of time before you buy another VX or Lotus!I think people confuse power oversteer (as per MBez's incident) and cornering oversteer. To quote a passage from Ross Bentleys book speed secrets "If the car begins to oversteer a little, squeeze on more throttle to transfer a little weight to lhe rear; if it starts to understeer, ease off slightly, giving the front a little more grip. When ii's done just right, all four tires are slipping the same amount-the car perfectly balanced, neither oversteering or understeering in a perfect neutral steer attitude through the turn."I really can't understand where this 'accelerate' crap comes from.
Posted 18 June 2013 - 08:07 AM
Yes, a great read thanks for the tip. At the moment I'm actually resisting buying that Atom 245 (they are based on Lotus dynamics) on Pistonheads that is going for just under £24K
Must...... not..... buy.....
Posted 18 June 2013 - 08:43 AM
Posted 18 June 2013 - 08:49 AM
Buy it and get it to the National!
Posted 18 June 2013 - 09:02 AM
I'm actually probably going to put £20K into a mortgage and use the extra £5K I have to start a 7 type self build (I've always wanted to build a car from the ground up)
I've been in talks with a company about one of these
Track only version
Edited by SteveA, 18 June 2013 - 09:04 AM.
Posted 18 June 2013 - 09:06 AM
by the time the mortgage is done, you will be too old to enjoy the spare cash
