Racelogic Traction Control
203 replies to this topic
#61 dw1
dw1
  • 3,043 posts
Posted 18 October 2013 - 11:38 PM
Is it possible to have the full throttle shift but without the launch control? Would want the digital adjuster too. In theory it would save 60 quid, can Mr Tuneconcept confirm this?
Looking at the Racelogic site it doesn't look like that is an option. I think when you have the digital adjuster, launch control just comes with it as a menu option.
#62 cs_
cs_
  • 213 posts
  • Interests:fast lightweight cars
    computers
    music
    home & family
Posted 19 October 2013 - 09:21 AM
Note: I will deliver the filter units for this group buy. These are the original ones. Tuneconcept is the only valid reseller for these units.
Line Filter Racelogic Traction Control to VX220/Lotus-ABS
The Racelogic is an absolutely great addon for our cars. You will love it.
#63 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 19 October 2013 - 09:32 AM
Big thanks to DW1 for picking this up while I have been away (also my initials are DW!)
1. westkenbrit - - RLTC6DIA (Up to 6 Cyl) + Launch Control + Digital Adjuster + NOISE FILTER + Full Throttle Shift + Clutch Switch 2. Dw1 - RLTC6DIA (Up to 6 Cyl) + Launch Control + Digital Adjuster + NOISE FILTER 3. Chris P Duck - RLTC6DIA (Up to 6 Cyl) + Launch Control + Digital Adjuster + NOISE FILTER
4. Starman - RLTC6DIA (Up to 6 Cyl) + Launch Control + Digital Adjuster + NOISE FILTER
5. Davemate -  RLTC6DIA + Launch + Digital Adjuster (black) + Noise Filters
#64 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 19 October 2013 - 02:28 PM
Note: I will deliver the filter units for this group buy. These are the original ones. Tuneconcept is the only valid reseller for these units.     The Racelogic is an absolutely great addon for our cars. You will love it.
Cheers CS, I saw a pic of these filter boxes and they had what looked like AMP Superseal connectors on. Are they supplied with these (or any other connectors) or just wires? I know you did a lot of work on the low speed signals. What's your suggestion as far as the abs wiring goes for best signal quality? Solder or a connector of some type?
#65 cs_
cs_
  • 213 posts
    computers
    music
    home & family
Posted 19 October 2013 - 03:05 PM
No connectors are delivered with it. They are not necessary. These are no high frequency signals, so no special connection is necessary here. You may solder, you may take a (good = sealed) connector, do as you like. But create a good connection. Do not take things like this here
Using such things (don't know the english name, in german we call them "Stromdiebe") will lead to signal problems after some time, because the connection is not very good and the copper tends to corrode in moist conditions.
One thing that came to my mind right now:
Be sure that the Racelogic Traction Control systems ordered are the ones with the "long ABS cables" for mid- or rear-engined cars. It's very important that the shielded cables are long enough to go through the sill to the front of the car, reaching the ABS ECU.
For wiring just take a look into the shortform I wrote in english. The positions of all components are shown there. Also the wiring diagram shown above is very important. If you wire according to it, you are on a good way.
Shortform
(you need a login to get there, just PM me to get it, it's not an open public blog)
#66 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 19 October 2013 - 03:14 PM
Thanks CS
#67 Darcini
Darcini
  • 2,508 posts
Posted 27 October 2013 - 09:43 PM
1. westkenbrit - - RLTC6DIA (Up to 6 Cyl) + Launch Control + Digital Adjuster + NOISE FILTER + Full Throttle Shift + Clutch Switch 2. Dw1 - RLTC6DIA (Up to 6 Cyl) + Launch Control + Digital Adjuster + NOISE FILTER 3. Chris P Duck - RLTC6DIA (Up to 6 Cyl) + Launch Control + Digital Adjuster + NOISE FILTER 4. Starman - RLTC6DIA (Up to 6 Cyl) + Launch Control + Digital Adjuster + NOISE FILTER 5. Davemate -  RLTC6DIA + Launch + Digital Adjuster (black) + Noise Filters 6. Darcini -  RLTC6DIA + Launch + Digital Adjuster (black) + Noise Filters
#68 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 28 October 2013 - 06:10 PM
1. westkenbrit - - RLTC6DIA (Up to 6 Cyl) + Launch Control + Digital Adjuster + NOISE FILTER + Full Throttle Shift + Clutch Switch 2. Dw1 - RLTC6DIA (Up to 6 Cyl) + Launch Control + Digital Adjuster + NOISE FILTER 3. Chris P Duck - RLTC6DIA (Up to 6 Cyl) + Launch Control + Digital Adjuster (black) + NOISE FILTER 4. Starman - RLTC6DIA (Up to 6 Cyl) + Launch Control + Digital Adjuster + NOISE FILTER 5. Davemate -  RLTC6DIA + Launch + Digital Adjuster (black) + Noise Filters 6. Darcini -  RLTC6DIA + Launch + Digital Adjuster (black) + Noise Filters Updated myself to black!
Edited by Chris P Duck, 28 October 2013 - 06:11 PM.
#69 aKra
aKra
  • 109 posts
Posted 29 October 2013 - 06:37 PM
I am not really sure whether I need this or not ;)
Edited by aKra, 29 October 2013 - 06:37 PM.
#70 siztenboots
Posted 30 October 2013 - 12:29 PM
dismantled digital adjuster box  (large image alert)
you could easily locate the display elsewhere, and have the adjuster pot on the steering wheel.
#71 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 01 November 2013 - 04:53 PM
Is anyone active on any others forums that we could join with to get the last 4? Be nice to get the full 20% off!
#72 aKra
aKra
  • 109 posts
Posted 01 November 2013 - 06:33 PM
Will post it on the Dutch forums!
#73 oggster
oggster
  • 886 posts
  • Interests:Staying alive 😉
Posted 01 November 2013 - 07:53 PM
if you don't mind me asking as i am interested,is this mainly for normal road use as a safety thing?or are most of you buying for using your cars on track? have had one or 2 we moments myself and think this could be a nice addition to have.
steve.
#74 Darcini
Darcini
  • 2,508 posts
Posted 01 November 2013 - 08:09 PM
if you don't mind me asking as i am interested,is this mainly for normal road use as a safety thing?or are most of you buying for using your cars on track? have had one or 2 we moments myself and think this could be a nice addition to have.   steve.
Speaking for myself it's purely for road use, and as it's fully adjustable presumably there's no reason why it wouldn't be of use on a track too.
#75 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 01 November 2013 - 08:14 PM
90% for road use to avoid SSSF or just F moments. 10% for dicking about (so on track obviously)
#76 Bill SC
Bill SC
  • 344 posts
Posted 01 November 2013 - 08:16 PM
Similar for me.... Traction control for road, especially crap weather LSD for track
#77 oggster
oggster
  • 886 posts
Posted 01 November 2013 - 08:17 PM
thanks,that what i thought.
if you get to a full 10 or more will it be a 20% discount on £850 or am i reading it wrong?
#78 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 01 November 2013 - 09:05 PM
It is a 20% discount, plus he has done a very good price on the filter box which has sold previously for 100 now 60. You don't have to go for everything. I am not going for full throttle shift so the full price for my order inc vat and delivery, the filter box and the shiny digital adjuster is £744. This would normall be £900 so quite a savings. The above from DW19 :D
Edited by Chris P Duck, 01 November 2013 - 09:06 PM.
#79 oggster
oggster
  • 886 posts
Posted 01 November 2013 - 09:20 PM
thanks chris....food for though for sure...full throttle is not for me either, i am just looking for a bit of traction safety,or rather lack of:) cheers for the info.
steve.
#80 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 01 November 2013 - 09:22 PM
Might be intrested will have a good think £744 is a good price :-)
